Industry Circles
Bryston Limited
Bryston BDP-1 error message no audio
0 Members and 1 Guest are viewing this topic. Read 819 times.
miatadan
Industry Participant
12 Feb 2021, 09:43 pm »
Need help with Bryston BDP-1 :
This on display. No firmware updates showing under support on Bryston site
error message ( Error 09 ) R02.0 2010-10-19
Dan
zoom25
Re: Bryston BDP-1 error message no audio
12 Feb 2021, 10:21 pm »
Remove power plug from the back for a few minutes and then re plug the power cable.
Also read the first few posts here:
https://www.audiocircle.com/index.php?topic=169436.0
You may need to change the battery. I suggest doing this anyway. Since I replaced the battery on mine, not a single Error 09 after that.
miatadan
Reply #2 on:
12 Feb 2021, 11:19 pm »
Changing the battery did the trick, thanks ))))
need password to login to bdp-1
what is default username and password?
Dan
gil99
ยป
Reply #3 on:
12 Feb 2021, 11:30 pm »
bryston, for both.
Gilles.
miatadan
Reply #4 on:
13 Feb 2021, 01:28 am »
Thanks for all the help
Dan
Industry Circles
Bryston Limited
