MPD versions question
0 Members and 1 Guest are viewing this topic. Read 1081 times.
NorthMac
« on: 11 Dec 2020, 05:47 pm »
This sort of involves Manic Moose, but is not really about MM, rather a query about how Bryston updates MPD versions.
With hindsight, it still seems a very good decision to base the Bryston digital playback on the open source MPD music player.  This continues to be supported, allows direct plugin of simple USB drive stored music files, and is now used by a good number of other manufacturers.  Best yet, it enables third party user interfaces which myself and I would guess at least half of Bryston owners are using.
And on that, I noticed that Berrie of Rigelian has added a new feature, ie. viewing of liner notes, directly from the Rigelian app.  However it needs MPD version 22 as a minimum.  This triggers a question I never thought of before, how do Bryston developers decide when to enable a new version of MPD?   The current v. 19 dates to about 2016.
So some questions:
1.  Can a new MPD simply be inserted in the MM dashboard, or does that require a corresponding set of changes within MM to facilitate whatever set of improvements the MPD update allows?
2.  Are new MPD versions becoming more challenging to incorporate, especially in the older Bryston players like BDP-1 or 2?
3.  Finally, is it likely that there will be essentially a "final"  MPD version that each player will allow?
« Last Edit: 12 Dec 2020, 05:57 pm by NorthMac »
unincognito
    • bryston.com
Re: MPD versions question
« Reply #1 on: 16 Dec 2020, 02:50 pm »
The reason we haven't updated MPD is because of how much an overhaul of the supporting libraries would required for anything after 0.19.x.  Traditionally when we've done this in the past we overhaul the entire firmware, but unfortunately we've put this off years longer then we should have, but it is currently being worked on.  Something should be released in 2021 and not only will it bring up to date versions of MPD but also many new cool features and a complete overhaul of the web ui as well.
Chris
NorthMac
« Reply #2 on: 18 Dec 2020, 01:00 am »
Chris
Thanks for that update Chris; that is more or less what I expected.  Of course we can "freeze" MPD in our systems and music will still play forever, but over time it seems user interfaces (presumably eventually even Bryston's own) will depend on having fairly late versions of MPD to access all the features possible.
drummermitchell
« Reply #3 on: 18 Dec 2020, 01:58 am »
Hopefully the Bryfi app is included with these upgrades.
