Servo sub wiring
0 Members and 1 Guest are viewing this topic. Read 1031 times.
Creative cut designs
Servo sub wiring
« on: 6 Nov 2020, 03:12 am »
I miss placed my instructions for the servo sub, not sure what pair of wires go to the driver coil and which pair goes to the servo coil?
morganc
Re: Servo sub wiring
« Reply #1 on: 6 Nov 2020, 03:12 am »
« Reply #2 on: 6 Nov 2020, 04:10 am »
Now to figure out how to wire the sub to my demon avr -s950h
mlundy57
« Reply #3 on: 6 Nov 2020, 05:12 pm »
Which servo sub did you build and with what drivers, 4 ohm, 8 ohm or 16 ohm? It makes a difference in whether you need to connect the sub to the main Left/Right speaker preamp outputs or if you can connect it to the AVR's LFE (SUB) output and use the AVR's bass management.
