Industry Circles
Bryston Limited
Monoblock Placement
Monoblock Placement
0 Members and 1 Guest are viewing this topic. Read 941 times.
ashtarul
Monoblock Placement
2 Nov 2020, 02:45 am »
This has probably been asked before but is it OK to permanently run monoblocks (28b) stacked on top of each other?
Facilitator
The Demo is Everything!
Re: Monoblock Placement
2 Nov 2020, 11:05 am »
Hi
A lot would depend on the speaker load but assuming normal loads and normal listening levels you should be fine.
The top amplifier may get a little warmer than the bottom amp due to convection but the amplifiers have built in heat detection which will shut the amplifier down if it gets to hot.
james
Rod_S
Reply #2 on:
2 Nov 2020, 12:40 pm »
I have run mine for years stacked after James gave me the same advice. The top amp definitely gets warmer. What I have done is just have a fan near by that continually blows air across the amps and that keeps both cool to only mildly warm.
john1970
Reply #3 on:
2 Nov 2020, 03:56 pm »
I have two 7B3 amps, but do keep them on separate shelves for the best heat dissipation. If I was purchasing two amps cost as much as the 28B3 I would definitely keep them on separate shelves with plenty of ventilation.
ashtarul
Reply #4 on:
2 Nov 2020, 04:20 pm »
Thanks gents!
Industry Circles
Bryston Limited
Monoblock Placement
