BDA-3.14 shows strange behaviour (again)
0 Members and 1 Guest are viewing this topic. Read 1143 times.
WillyP
« on: 30 Aug 2020, 12:24 pm »
Hi James,
The last few days my BDA-3.14 shows very strange behaviour. The music on my USB hard disk is organized in folders but the BDA-3.14 saw only a few files from the first two folders. In that stadium, it could play music. Later on, all folders seem to have disappeared and there was no sound anymore. I have checked the hard disk, but there was nothing wrong with it. All maps and files were there.
I tried the usual tricks: update, reboot, factory reset, all to no avail. The only thing that worked, was to remove the power cord for a few minutes and then everything seems OK. For the time being, that is.
This happened two times now, within a few days.
FYI, the hard disk is formatted in exFAT, but I have also tried my backup hard disk (one at a time), that is formatted in FAT 32 and the other format didn’t make a difference. Both disks use less than 200 mA, so they are not drawing too much current from the BDA-3.14.
According to Manic Moose, the unit is up-to-date. The firmware version is BDA314_2020_04c. I know there is a newer version available for the BDA-3, but I don’t know if this version also is correct for the BDA-3.14.
Do you have an idea what was going on? Is there anything I can do to prevent such problems?
WillyP
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-3.14 shows strange behaviour (again)
« Reply #1 on: 30 Aug 2020, 02:11 pm »
Hi James,
WillyP
Hi Willy
Sorry I do not - I have had no issues with my 3.14.
I will ask Chris to see what he thinks and if you put your 3.14 in Service mode Chris could have a look.
james
unincognito
    • bryston.com
« Reply #2 on: 30 Aug 2020, 02:59 pm »
Sorry I've been a bit tardy with BDA-3.14 issues as of late.  There is an update I'm preparing for release that will fix some stuff that is related to the Pi platform and integrated products (BP18 development); however I should finally have time to address BDA-3.14 specific issues in the next couple of weeks.
Chris
WillyP
« Reply #3 on: 31 Aug 2020, 05:47 pm »
Hi Willy
james
Hi James,
Thanks for the quick reply. Chris has already answered.
WillyP
WillyP
« Reply #4 on: 31 Aug 2020, 05:49 pm »
Chris
Hi Chris,
Thank you for the quick reply. It is good to know that you are working on it.
Does it help if I put the BDA-3.14 in service mode or are you familiar with the issue already?
What is the preferred format for the USB hard disk (1 Tb): exFAT or FAT32?
Kind regards,
WillyP
« Reply #5 on: 31 Aug 2020, 06:56 pm »
Hi Chris,
Kind regards,
WillyP
Hi Willy
I use exFAT on all my harddrives.  Just as a test have you tried a thumbdrive?
james
WillyP
« Reply #6 on: 31 Aug 2020, 07:10 pm »
Hi James,
I have tried a few thumbdrives, in exFAT and FAT32 and they all work without problems.
WillyP
