Cable design.Bundle of same ga. or bundle of different ga.?
0 Members and 1 Guest are viewing this topic. Read 1285 times.
SET Man
Hi all. :D I have been looking to change my cable between my pre and amp. As a DIYer I can't help thinking of rolling them myself.
Anyway, there are many desings out there. My aim is to get final gauge of about 18-20ga. But I can't seem to choose between multi-strands of the same gauge (e.g. 31ga) Or multi-strands of different gauges (e.g. 33ga+31ga+29ga) Which do you think would be a make a good 2.5 meters run of cable?
Also, is there an easy way to calculate the final ga of multi-strands of different sizes?
Anyway, comment and help would be greatly apriciated.
Buddy :thumb:
JoshK
« Reply #1 on: 1 Mar 2005, 12:57 am »
I think you might want to check out VenHaus' free silver IC recipe. They are damn nice ICs.
SET Man
« Reply #2 on: 1 Mar 2005, 01:09 am »
Wow! :o That was a fast respond.
Thanks Josh. I found the site. Silver, simple and cotton insulated! Very interesting. I will have to do some more investigating on this.
Thanks again Josh. Maybe I'll see you at the next rave.
Buddy :thumb:
andyr
Re: Cable design.Bundle of same ga. or bundle of different g
« Reply #3 on: 1 Mar 2005, 06:58 am »
Quote from: SET Man
Hi all. ... Also, is there an easy way to calculate the final ga of multi-strands of differen ...
Here's a very useful cable guage table.  It gives you the mm^2 of each guage so you can simply add 'em up!
www.vandenhul.com/artpap/awg.htm
Andy
SET Man
« Reply #4 on: 1 Mar 2005, 09:23 pm »
Hi Andy. That's perfect! :D Just what I have been looking for. Seem to be easier than I thought :lol:
Thanks again for a very useful link.
Buddy :thumb:
