0 Members and 2 Guests are viewing this topic. Read 17104 times.
There are several to choose from. Do you have a budget in mind ? Basically any quality SS amp with 200W/ch will do just fine. To be specific provide a price range. Remember it is not just the amp. It is a system.charles
Respectfully feel the above has put the cart before the horse. The OP doesn't write what amp will work best with my (i.e. his) planers. If that's the OP's intent he should write so. The amps which works best with one set of speakers in a particular environment (e.g Quad ESL in a small live room) will not necessarily be the amps which work best in an different setting (e.g. Magnapan 3.n in a large, heavily carpeted & upholstered room.) I suggest the OP clarify the direction of his thought so we may better reply. FWIW, I've used a Classe CA200 and/or EAR 509 with ML Quests for c.30 years. Passively biamped when and.As always YMMV,/mp
My favorite amp for the system was a Plinius at the time.
Hi,To clarify, I was just asking what you have and what you are happy with.Happy since many of us try different amps till we settle on one.Definitely YMMV.Legendary Pass with legendary price, can’t touch those. I bet they are quite amazing.Thanks for the replies. Seems Pass and Brystons pop up often. I did get a used Khartago Stereo, will set up in few weeks.
Lynxo,That Kahartago might just be sweet with Maggies. Please let us know how you like it.Here is what my XO looks like:
