Requesting help with a notch filter
0 Members and 1 Guest are viewing this topic. Read 2216 times.
Larpy
« on: 12 Jul 2020, 08:52 pm »
I'm using Lii Audio F15 drivers as my main speakers and, just in the past two months, I've added stereo GR Research servo subs in H-frames.  For the most part, I'm delighted with the sound: with my Radio Shack SPL meter (calibrated to correct the meter's shortcomings in low bass and upper treble), I measure +/– 3 dBs from 25 Hz to 5K Hz, but between 6K and 7K there's a 6 dB spike.  I'd like to try building a notch filter to smooth this peak.  I haven't done this before and I'd like some guidance.
According to diyaudioandvideo.com's Parallel Notch Filter calculator, I should use a 1.87mH inductor and a 75uF capacitor.  As I understand it, this is a straightforward matter of adding the inductor and cap in parallel before the positive terminal of the F15 drivers.  A resistor (the calculator suggests a 2.65 ohm no matter what attenuation value I choose) also in parallel determines the amount of attenuation.
I ran a frequency sweep through GarageBand (I'm pretty low tech) using its parametric EQ to simulate a notch filter that attenuated 4 dBs at 6.3K with a Q of 5.0 and that smoothed out the peak fairly well.
Before I order parts (from Danny), I want to make sure what I'm planning makes sense.  Should I indeed use a parallel notch filter? With the above mentioned values for inductor and cap?  What resistance value will give me 5 dBs of attenuation?  According to Lii, the F15's impedance between 6K and 8K is 12-15 ohms.
Or is a series notch filter a better idea?  If so, why?
As I said, I'm a hobbyist who's comfortable building amps, but I'm brand new to DIY speaker building.  I appreciate any help you can offer.  Thanks.
« Last Edit: 13 Jul 2020, 08:51 pm by Larpy »
Larpy
Re: Requesting help with a notch filter
« Reply #1 on: 13 Jul 2020, 06:16 pm »
I've been searching past posts in the GR circle that mention notch filters and found this one:
https://www.audiocircle.com/index.php?topic=103006.0
Reading that thread, it looks as though what I need is what Danny calls a "shunt filter" that sends the notch frequencies to ground.  So such a notch filter is not parallel but series, and in series from the positive terminal to the negative terminal of the speaker.
Am I understanding this correctly?  Or does Danny's advice in the thread above only apply to a notch filter added to a woofer/tweeter crossover and not a FR driver like I have?
If I use a parallel notch filter, I'll need a 75uF cap and, since it's in line with the FR driver, I hesitate to use something like a Solen cap, but 75uF is a hefty cap and serious money for a high quality cap.  So would using a shunt series filter allow me to use a lesser cap and not compromise the sound?
Playing with the parallel notch filter calculator, if I widen the bandwidth of the notch just a little, I can use a 40uF cap and a 1mH inductor.  That would be more reasonable for cost.
But I still don't understand if I should use either a parallel notch filter in line with the driver or a series filter to ground or if either one would work.
« Last Edit: 13 Jul 2020, 09:11 pm by Larpy »
Danny Richie
« Reply #2 on: 14 Jul 2020, 09:02 pm »
I just measured one of those drivers last week for a customer. That was not a full range driver. It did have a peak at about 6kHz but it fell like a rock after that. There was no top end.
I wish I would have saved the raw driver measurements.
I designed a two way crossover for it and a large voice coil tweeter and it worked out pretty well.
Larpy
« Reply #3 on: 14 Jul 2020, 09:29 pm »
My pair peak at 6.5K but there's a flat shelf between 7K and 10K.  Around 11.5K they drop like a rock, with virtually no output at all above that.  But my ears can no longer hear 12.5K, so it's not a problem for me.
So I don't need a tweeter but a fix for the 6.5K peak.
I wonder if the pair you measured hadn't been fully broken in yet.  My pair sounded dreadful for the first 30 hours.
Danny Richie
« Reply #4 on: 15 Jul 2020, 01:14 pm »
Burn in doesn't effect the measure frequency response. It can effect it a little below 200Hz, but that is way out of the range in question.
I can calculate a real notch filter for it though to fix the 6kHz peak.
Larpy
« Reply #5 on: 15 Jul 2020, 04:32 pm »
That would be great.  Thank you!
Danny Richie
« Reply #6 on: 15 Jul 2020, 05:09 pm »
Okay, I configured one from some measured impedance sweeps. I have all of the parts in stock and the cost is not very much. Just give me a call.
alanhuth
« Reply #7 on: 2 Feb 2022, 06:42 pm »
HI Danny,
In case you are tracking new posts here, this is the thread about Lii F15 notch filter.
I want one.
Alan Huth
alanhuth
« Reply #8 on: 4 Feb 2022, 04:17 pm »
Bump
