0 Members and 1 Guest are viewing this topic. Read 53443 times.
At that price range, would look at this:https://www.vandersteen.com/products/model-2ce-signature-iiiIt's slightly over 3k, but a well regarded speakers from a reputable manufacturer.
Thanks to all for the great suggestions!Keep them coming!Just a quick note.... The search is for speakers that can play loud without risk of damage. By loud, I mean 110dB+ peak to the listener. I typically use c-wt for measuring SPL at the listening position, by the way. ....This means speakers with "little woofers" probably won't cut it.Here's an easy-to-use SPL calculator:https://myhometheater.homestead.com/splcalculator.htmlAs a reference, let's use KING Maraschino amplifiers, which can conservatively deliver 400Wpc into 4Ω (200W into 8Ω, 270W into 6Ω) in a 2-channel system. With a "standard listening distance" of 8 feet, 4Ω speakers rated at 88dB, the KING Maraschinos will deliver >111dB SPL peak.
