SOLD: Tekton Design Pendragon (version 1) in Portland/Oregon
0 Members and 1 Guest are viewing this topic. Read 991 times.
eboleyn
These have been SOLD, thanks!
Tekton Design Pendragon version 1, i.e. the original production version before his shift to the current "horn-style" tweeter crossover.  I'd moved my living room to Tekton Double Impacts with upgraded crossovers a few years ago and the Pendragons got moved to my "lab" space for music/light tv use.  They still work as well as they did originally as far as I can tell.
Selling because I'm now moving my living room to a custom-built digital crossover/tri-amped setup, so one of the sets of big Tekton floorstanders have to go  (I suppose if someone asks about the semi-gloss black Double Impacts with charcoal grills I'd consider those too, but the Pendragons are what I'm listing...).  The Double Impacts are indeed better, but not hugely so and I still consider them to be roughly in the same "class" for overall listening quality, and only recently had I heard something which was a big step up (the custom built stack which ends up being much more expensive to get to that next level, but hey it's a hobby for fun so I'm going for it).
Thinking of $900 obo, will entertain reasonable offers.  Want to keep it local pickup in Portland/Oregon since my boxes are long gone (I have the Double Impact boxes which would *mostly* fit, but currently disinclined to try that).
Stats:
  • 2 - 10" "Pendragon" transducer
  • 3 - 1" tweeter  (SB Acoustics ring radiator)
  • 4 Ohm impedance
  • 98db 2.83V @ 1M  (2 watts since 4 Ohm)
  • Frequency response  20Hz - 30kHz (I generated white noise in the 20-20k range once and the eyeballing the FFT looked surprisingly flat!)
  • Height 54" x Width 12" x Depth 16"
  • 89 lbs per speaker
They are painted in a semi-gloss/semi-matte deep forest green color.  Note there are a few pinhead or smaller sized nicks in the paint that are not very visible.
Pics:
« Last Edit: 20 Jun 2020, 02:46 am by eboleyn »
eboleyn
Re: SOLD: Tekton Design Pendragon (version 1) in Portland/Oregon
« Reply #1 on: 20 Jun 2020, 02:47 am »
These have been sold, thanks!
