black diamond racing cones on wadia 861b
0 Members and 1 Guest are viewing this topic. Read 1099 times.
scottielee
« on: 18 Feb 2005, 03:25 pm »
hi,
does anyone hear an improvement of sound replacing the stock spikes with black diamond racing cones on wadia 861b? do the bdr cones screw in perfectly on the 861b?
thanks for your time!!!
scottie
nhtran
« Reply #1 on: 18 Feb 2005, 06:33 pm »
I tried the Mk 3 cones w/ a Wadia 830...didn't like it at all.  The BDR's attenuated the lower-to-mid highs, gave it a kind metallic quality.  I got the same effect using it under my amp.
I prefer the DH Labs Golden Sound cones.
If you're interested I will sell you my BDR's so you can try it on your CDP.
