0 Members and 1 Guest are viewing this topic. Read 19920 times.
x2
Great choice. Holger makes beautiful gear.
So I'm seeing that you need larger transformers to handle the likes of KT120's and KT150 tubes which I read are providing a little more top and bottom end than, say, a KT88. Not sure how a 6550 compares to those. AAnyways, you have to be careful not to buy an older version with underpowered transformers and then try to use 120's or 150's and overtax the unit.I'm also reading more reviews and see that Raven, Ayon, Line Magnetic (not sure still in business), Cary, and Rogue seem to be good products.
I had the Classic MKII for 3 years it was light in it's shoes on the low end. It was running 130watts/ch into 4 ohms here. The Cronus MAG II will kill it in most areas especially the low end. The Mag II has lots of slam and low end. My Schiit stack sounds better too.As always everything speaker/room treatments dependent. But you know that.
Anyone have a Rogers?
Rogers
McIntosh
Hello : I had the Ayon Spirit 3 and though it was a nice unit, I sold it and purchased a Leben CS-600 and can honestly say the Leben was quite a bit more Musical and head and shoulders above the Ayon..The Leben is the quietest Tube unit I have ever owned and the most enjoyable too...Good luck with your choice..
