0 Members and 1 Guest are viewing this topic. Read 5860 times.
We have been asked so many times recently about the STM versus the new 2-CHerry amplifier, so here's a quick note on the differences....STM has an input select (front/back) and volume control. The 2-CHerry is a "plain amp" without any preamp features. The STM also has a selectable sleep mode (on/auto/off). The 2-CHerry is set to auto-sleep unless the no-sleep option is selected at the time of purchase.The 2-CHerry has several advantages over the STM. One is the power supply to amplifier path. All x-CHerry amps (2-CHerry, 3-CHerry, 4-CHerry, 5-CHerry) have Power Pipes™ to connect the power supply to the amp channels. This is in an effort to reach the lowest resistance possible to the amplifier channels. The STM has an external power supply, so the power goes through several connectors and a DC Cable (DC_SNAKE is standard with the KING STM, 3-ft or 6-in length available). The 2-CHerry also has triple rail capacitance, now even with the standard version. This is not possible with the STM, which can have double rail capacitance at most. The 2-CHerry also features lower THD+N across most of the power band. Both have that "sweet Cherry sound" !!Another aspect is price. The STM is priced significantly lower than the 2-CHerry. Current list prices (in USD): Standard STM: $1200 (MK1) -- MK2 upgrade is $290 KING STM: $1700 (MK1) -- MK2 upgrade is $290 Standard 2-CHerry: $2490 KING 2-CHerry: $2990
What are the benefits of triple rail capacitance?
Can anyone comment on the differences between the 2-Cherry and the Maraschino Monoblocks? Specifically in regards to Bass, Tone and Harmonics. To my ears the 2-Cherry has much better bass and more tube like tone as harmonics than does the STM. Is that also the case with the Maraschino Monoblocks?
Thanks Tommy for the specs and would love for you to comment on the sound quality difference as well.
Tommy, while researching the X-CHerry line, I noticed this point about the multi channels, does this mean that the standard version does not have double rail caps?“Double rail cap on King 3, 4, and 5-CHerry”
Currently all 2-CHerry and 3-CHerry have triple rail caps.Currently all 4-CHerry and 5-CHerry have double rail caps.This is true for KING and standard versions, so the KING versions have faceplates and Gold WBT binding posts, otherwise, they are the same as the standard versions.
Can anyone comment on preamps that they use with the 2-Cherry amp or suggest what types would be the best type of match
