Hello😀
0 Members and 1 Guest are viewing this topic. Read 545 times.
Dhananjeyan
Hello😀
« on: 22 Feb 2020, 01:13 am »
Hello I was just researching speakers and came across this forum from new record days videos. I’m from California.
Thank you,
Dhananjeyan
Re: Hello😀
« Reply #1 on: 22 Feb 2020, 01:32 am »
Welcome Dhananjeyan :thumb:
Re: Hello😀
« Reply #2 on: 22 Feb 2020, 01:47 am »
Greetings & Welcome to AC Dhananjeyan    :thumb:
Phil A
Re: Hello😀
« Reply #3 on: 22 Feb 2020, 05:59 am »
Welcome!
Wind Chaser
Re: Hello😀
« Reply #4 on: 22 Feb 2020, 06:06 am »
Welcome to Audio Circle. :D
Dhananjeyan
Re: Hello😀
« Reply #5 on: 28 Feb 2020, 11:53 pm »
Hello all,
Thank you for the welcoming. I was wondering what day should I get my budget is $1500 and can go to $2000 if it is really worth it. Willing to diy just looking for the best possible option. Which thread should I use for my research.
Thank you,
Dhananjeyan Natarajan
Re: Hello😀
« Reply #6 on: 29 Feb 2020, 12:49 am »
If you have a carpenter near, I would suggest the Lii 15 at $399 pair, bargain, in a OB barrel.
A simple OB fullrange driver if you have space in your room, a easy to made 15''($399/pair) floorstander not tiny mini monitor.
https://www.audiocircle.com/index.php?topic=166224.0
https://www.decware.com/newsite/ZMS.html
Completely crossoverless.
A perfect point source.
Single driver with 50~17kHz from one voice coil.
100 dB 1w/1m
13.7 grams of moving mass
No box
No shout
No peaks
Great bass performance
