0 Members and 1 Guest are viewing this topic. Read 4353 times.
Hello, I was wondering what was the collective though on class D amplifers, I just installed a 6 custom class D monoblocks in my studio to power an Augspurger system, three way, all original TAD components and it sounds cleaner , faster and more accurate than tube and mosfet amps... thoughts?
I can’t speak for the collective, but I for one am done with tubes!
I can't say I'm done with them...but I'm certainly all in with SS at the moment!
A great sounding amp is a great sounding amp, regardless of what “class” it uses. I’ve heard great sounding Class A, AB, D, G, tubes, et al. I’ve also heard awful sound examples of each one. One type of output doesn’t make something inherently better nor worse than everything else.
What’s missing is usually noise. It takes some time to get used to the absence of noise. Good class D is extremely silent behind the notes. Almost sounds fake if you are coming from noisy amps. Don’t get me wrong I love vinyl, tubes, analog tape, etc.But silence is golden. On really good recordings The music just appears without an audible source. That affect can be intoxicating. Hard to go back to “colorful” amps even if they are fun. You can always hear what they add on to the source.
Maybe you haven't found the right Class D amp?
The best preamp IMO is no preamp. The simpler and shorter the signal path from source to speakers the better - again that’s just my opinion.
