Bryston BDP1-Memory Issue?
0 Members and 1 Guest are viewing this topic. Read 951 times.
XKevinX
« on: 23 Dec 2019, 03:47 am »
New to using my BDP1 to stream Tidal.  I have noticed that songs over 7min in length just stop and jump to the next song.  Under Services, memory shows over 96%.  Is this the cause of the issue?  I’ve seen posts that refer to clearing the cache, but I can’t seem to figure out how to do that.  The one button I found wants me to log in with a user name and password??
Any suggestions would be appreciated.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BDP1-Memory Issue?
« Reply #1 on: 23 Dec 2019, 12:43 pm »
Hi Kevin
User name and password are both - bryston
james
XKevinX
« Reply #2 on: 23 Dec 2019, 06:53 pm »
Thanks James, do you suspect this should resolve the issue? I have had my BDP1 since Aug 2012 and have never cleared the cache.  For some reason i thought turning the unit off would have done this.
« Reply #3 on: 23 Dec 2019, 07:32 pm »
Not sure on the cache question - will leave that one to Chris.
james
