Considering active crossover on Super Tower II's, modified/updated
0 Members and 1 Guest are viewing this topic. Read 1731 times.
RSorak
I've come into an abundance of amplifiers and this has gotten me interested in the idea of bi amping my speakers w an active crossover. The overall idea is to drive the 15's w a Beringer NX3000 and the rest of the drivers with a Parasound HCA2200 using the stock passive crossover for the drivers powered by the Parasound.
I've gotten a minidspHD 2x4 to do the crossover work between the 15 and the rest of the drivers....What I need help w now is the XO for the Parasound part of the system, plz see my last post.
Rick
« Last Edit: 24 Nov 2019, 10:51 pm by RSorak »
HAL
Re: Considering active crossover on Super Tower II's
« Reply #1 on: 15 Nov 2019, 03:07 am »
Here is something I did as an DSP crossover for a friends VMPS RM50's.  Still using it today:
https://www.audiocircle.com/index.php?topic=144466.0
RSorak
It appears the only affordable DSP is the miniDSP 2x4 HD, this will do what I need and more....
https://deercreekaudio.com/products/minidsp-2x4-hd-and-umik-1-combo
RSorak
I need help w modifying the XO, if I remove the 15" from this XO what happens to the function of the XO? I ask because I've learned this is a series XO and removing the 15 will most likely "break it". Is there any simple acceptable mod to this crossover work w/o the 15? If not what is the best fix IYHO?
Rick
RSorak
After consulting with John Cassler, I've decided to leave the speakers as be {modifying the serial crossover by removing the 15 would break it for ALL remaining drivers with no easy fix} and use the DSP for running additional subwoofers...I have 2 VMPS original subs that are unused ATM.
