0 Members and 1 Guest are viewing this topic. Read 6316 times.
Based on the work of Toole, full range tower speakers are dinosaurs.
JLM - so exactly what do you call the JBL speaker in his living room then? see the link that follows.....https://www.thescreeningroomav.com/single-post/2019/03/06/The-Ultimate-Real-World-Home-Theater-and-Listening-Room
Dinosaurs in a tastefully decorated room vs Tooles fugly room? I’ll take my dinosaurs every day. Want ‘being there’ sound? Get out and go to a concert.
TLDR: In reviews I hear monitors frequently being called small sounding. Is this because they don't have the lower frequencies properly covered and with good subs, would sound "large"?.... ....So I'm looking at other monitors to put on top of my subs. Assuming I'm thinking accurately, I should be looking for a monitor that doesn't try to do everything because my subs will pick up the low end. Should I be looking for specific HZ and KHZ ranges? ......
The point being, the ideal in-room place to generate bass is nearly opposite that of midrange/treble
Bass behaves as waves, up to the "cross over" (Schroeder) frequency which is roughly 120-200 Hz (room dependent) so should be generated from near corners.
