U Frame OB with side mounted drivers
0 Members and 1 Guest are viewing this topic. Read 1845 times.
sfdoddsy
« on: 24 Jul 2019, 10:49 am »
A few years back when the Wedgie was introduced there was discussion about a U Frame OB with side mounted bass drivers to use as a stand:
https://www.audiocircle.com/index.php?topic=126112.msg1331168#msg1331168
Did anyone actually build this?
It would fit perfectly for something I am looking at, but I'm struggling to see how it works.
Given the position of the drivers, it seems like there is minimal separation and hence you'd need a lot of EQ.
Any thoughts from builds?
Danny Richie
Re: U Frame OB with side mounted drivers
« Reply #1 on: 24 Jul 2019, 01:59 pm »
I built some of these stands using our 8" servo subs: https://www.audiocircle.com/index.php?topic=129161.0
They sounded great and didn't load the room too much either.
But the open backed designed using just two 8's had limited output. They were only good for small rooms.
« Reply #2 on: 24 Jul 2019, 04:10 pm »
If their output was limited to only 30hz and above, would that enable more output?
I'm thinking of the Super Mini - the 8inch subs going to 30hz with lots of output and a stand that matches the style of the main drivers would be pretty sweet.
mlundy57
« Reply #3 on: 24 Jul 2019, 04:30 pm »
I built a pair of those stands to mate with X-CS Encores. This was a combination music/home theater system so the stands were crossed to a sealed servo sub at 30Hz and worked fine.
Mike
« Reply #4 on: 25 Jul 2019, 03:55 pm »
These may also be a solution for you although, you'd   still want a  sub for the bottom couple  octaves
Reply  #90
https://www.audiocircle.com/index.php?topic=164376.80
Thee are being cut  and  will be  sending  a pair to Danny soon.  They  match the Super Mini perfectly and are fully braced  similar to the  NX-Otica's
jay
sfdoddsy
« Reply #5 on: 26 Jul 2019, 11:13 am »
Thanks for the link to the full build and the honesty about the results.
Given the end result seems to be a slotted port with more output to the rear, wouldn’t a sealed stand with one driver have the same effect?
Or even an H frame with the same dimensions?
The V baffle wouldn’t work aesthetically with any satellites other than Wedgies or similar.
