How does this all Visaton Open Baffle design look?
0 Members and 1 Guest are viewing this topic. Read 3022 times.
DaveFred
« on: 23 Jul 2019, 02:10 am »
I have been trying different baffle layouts where I can place the drivers all in the centre so their radiation patterns are symmetrical, and this is what I have come up with.
What do you think of this layout?
About the tweeter, do you think I am crossing the G20SC too low, or does it look fine?
For the crossover, I have used real values for everything of components I can source locally with correct OHM resistance for each. I used a 16g laminated steel inductor on the woofer and for the 10mH on the mid, everything else is 18g air core.
How accurate is Boxsim on open baffle designs like this?
I used the instructions from Rudolf on how to set up Boxsim for open baffle designs.
Is there a way I can upload the Boxsim .BPJ file for you to look at as well?
Comments?
Thank you,
David
Re: How does this all Visaton Open Baffle design look?
« Reply #1 on: 23 Jul 2019, 02:24 am »
When you said all Visaton I think was an all B200 system,
This LA was made by an AC member:
JohnR
« Reply #2 on: 23 Jul 2019, 06:01 am »
Well, it looks pretty good, your simulation is based on measurements of the drivers? I suppose the main limitation would be SPL at low frequencies.
BTW I added the WS 25E to the list of OB drivers  :thumb:
