X-MTM Encore build log
ntjetsmoke
Re: X-MTM Encore build log
« Reply #20 on: 25 Jul 2019, 09:45 pm »
Jeff,
I have follow up questions I hope you will help me with:
1. Did you use HOK primer and clear coat? If not what brand did you select?
2. The bin shellac - did you thin it down? What ratio of bin to thinner is correct?
3. Have you finished your speakers? How did you finish your pair?
Thank you
ebag4
« Reply #21 on: 25 Jul 2019, 11:55 pm »
Great job and incredible finish!  I’m certain your buddy will really enjoy.  Thanks for sharing.
Best,
Ed
jeffwhetstone
« Reply #22 on: 26 Jul 2019, 12:30 am »
Thanks Ed.   Yes, my buddy is really enjoying them.
Ntjetsmoke,
1)  No, I cheaped out and used the primer and clear I had on hand.   What I used was:
Speedokote SMR-210  Grey 2K Primer   w/ SMR-211 activator
Speedokote SMR-1150  Urethane Clear   w/ SMR-1102-Q Activator Medium.
Fortunately, I had no compatibility issues.
2)  Nope, I sprayed the BIN straight from the (fresh) can.   It doesn't require any thinning when spraying with a 1.4mm tip.   If you have a can that's been open for a while you might want to add a little denatured alcohol.
3)  Unfortunately, no.   Life is getting in the way, and I decided I'm not going to paint my X-MTMs until I finish building the matching center and rear channels, and subwoofers.     Hopefully later this fall.    Still leaning towards metal flake though...
Jeff
ntjetsmoke
« Reply #23 on: 26 Jul 2019, 04:09 am »
Jeff,
Thank you for your quick response to my questions. Your answers are very helpful.
My progress to become a painter looks like this:
1. Bought a sheet of 1/2 inch mdf and cut it into 2' x 2' squares.
2. Bought rattle cans of Kilz and Zinsser shellac.  Cans of guide coat, 2K primer, and 2k clear coat.
3. I sanded test pieces with 150 grit paper and then sprayed the Kilz and the Zinsser on to respective test squares. Using the guide coat to
    gauge progress. I applied three coats of the respective primer / sealer using the guide coat after each new coat. Sand paper grit went from 150 followed by 220 grit and then 320 grit.
4. I then sprayed both with the 2K rattle can primer and sanded with 600 grit. Note: both test pieces became flat but the piece withe the Kilz
  required more sanding to achieve the same flatness. I then sprayed  three coats of rattle can glossy paint  followed by the rattle can 2K clear coat. The next step is to buy a HVLP gun and the sealer / primer / base coat / clear coat and practice technique on each step including flatting as needed.
Again, your build log and continuing input makes a significant difference in my progress, thank you!
Scott Poerschke
« Reply #24 on: 19 Oct 2020, 04:30 pm »
Can you send me a PDF of the cut sheets to [email protected]?   There is a picture of the cut sheet in the first photograph on this thread.
Thank you,
Scott
adminRH
  • not admin
« Reply #25 on: 19 Oct 2020, 09:50 pm »
Can you send me a PDF of the cut sheets to ?   There is a picture of the cut sheet in the first photograph on this thread.
Thank you,
Scott
When you get 3 posts you can send him a private message.
Then PM me to delete this post with your email so you don't get spammed.
jeffwhetstone
« Reply #26 on: 20 Oct 2020, 04:02 am »
Email sent!
bithloman
« Reply #27 on: 28 Jan 2021, 03:50 am »
Jeff
Hello i am currently building the mtm encore speakers. anyone know where i can find the layout for the crossover? i have the schematic but finding it very basic and need some help thanks
mlundy57
« Reply #28 on: 28 Jan 2021, 06:18 pm »
Here's a link to my X-CS Encore & X-MTM Encore (same speaker just different cabinets) build thread. Reply 32 on page 2 shows how I laid out the crossover.
Mike
mlundy57
« Reply #29 on: 28 Jan 2021, 06:19 pm »
https://www.audiocircle.com/index.php?topic=128392.20
Mike
bithloman
« Reply #30 on: 28 Jan 2021, 06:37 pm »
perfect i saw that but since there are 3 i wasnt sure if it was for for the x mtm encore or the other speakers you were also building. thanks! where do the positive and negative wires that lead to the binding posts attach?
bithloman
« Reply #31 on: 28 Jan 2021, 06:39 pm »
actually i think i see you attached all positive and negative too two separate points to attach the wires. makes sense.
Mekic
« Reply #32 on: 7 Mar 2024, 07:54 am »
Hi,
Can you please add some pictures of damping? I see that kit doesn’t include damping material, and recommend is approximately 100USD. I wonder what have you used?
Kind Regards to all
