Pi4 out
0 Members and 1 Guest are viewing this topic. Read 1877 times.
randytsuch
Pi4 out
« on: 24 Jun 2019, 02:31 pm »
Just saw an email announcement about this
https://www.raspberrypi.org/blog/raspberry-pi-4-on-sale-now-from-35/
I may upgrade the one I use for home automation/IOT stuff, should be faster.
Randy
JohnR
Re: Pi4 out
« Reply #1 on: 24 Jun 2019, 02:52 pm »
"Full-throughput Gigabit Ethernet"
Will be nice to have no more USB conflicts. Watch out for the different port formats tho. Thanks for news, anyone want an almost new 3B+ :-P
randytsuch
Re: Pi4 out
« Reply #2 on: 24 Jun 2019, 03:05 pm »
Benchmarks
https://medium.com/@ghalfacree/benchmarking-the-raspberry-pi-4-73e5afbcd54b
Since USB and Ethernet are now separated, as you would expect, both are MUCH faster.
Issue will be heat.  If you put in a case, may want active cooling.
I expect there will be larger cases made, with bigger passive heatsinks.
Since a lot of these will be sold, I'm sure there will be some cooling options after a bit.
Randy
JohnR
Re: Pi4 out
« Reply #3 on: 24 Jun 2019, 04:37 pm »
It seems to take awhile for it to heat up. I wonder how many audio distros and HATs will work as is.
randytsuch
Re: Pi4 out
« Reply #4 on: 24 Jun 2019, 04:39 pm »
Another article/review
https://www.tomshardware.com/reviews/raspberry-pi-4-b,6193.html
Seems like buster from Raspberry for OS.  Until this morning I didn't even know that Buster was replacing Stretch
I would expect it may take a little while before audio is working correctly.
Randy
JohnR
Re: Pi4 out
« Reply #5 on: 25 Jun 2019, 02:06 am »
Oh right, looks like Buster is the standard download for all platforms now - https://www.raspberrypi.org/downloads/raspbian/
Well I guess the 4 addresses longstanding criticisms of the Pi... !
audiobomber
Re: Pi4 out
« Reply #6 on: 25 Jun 2019, 03:03 am »
I don't see any advantage for audio? I guess if you use a USB 3.0 DAC that could be a minor upgrade.
randytsuch
Re: Pi4 out
« Reply #7 on: 25 Jun 2019, 12:55 pm »
They finally separated USB from Ethernet.  Advantage here will mostly be in data throughput through each since they no longer have to share the same data pipeline, but this could improve usb audio out from the pi.  I never used usb audio from a pi, only used I2S audio.
But otherwise, advantages are for video and speed, not for audio.
audiobomber
Re: Pi4 out
« Reply #8 on: 25 Jun 2019, 01:38 pm »
Thanks, you're right, that will be better. I found the sound much improved when powering the DAC externally instead of via the RPI 3 B+ USB bus.
