Splitting after passive pre
0 Members and 1 Guest are viewing this topic. Read 1587 times.
ryno
« on: 1 Feb 2005, 01:32 am »
Is there a problem with splitting the signal after a passive preamp? What do I need to look out for? One pair would go to a full range amp, the second to a sub, possibly through an external xover/eq, so I need low level not high. Or, is there a passive with dual outputs?
Thanks Ryan
Re: Splitting after passive pre
« Reply #1 on: 1 Feb 2005, 02:20 am »
Quote from: ryno
Thanks Ryan
Hi Ryan. One of the major things to look out for is the total capacitance of the ICs, esp with passive/resistor types. Want to keep it as low as possible.
Hope this helps.
Rich Carlson
« Reply #2 on: 1 Feb 2005, 11:29 am »
Ryan - My experience with this was not very successful, resulting in a definite lack of impact in the bass. I attribute this to the relatively low input impedance of my subs, and the need to run relatively long cables. But I think your success will depend on the specifics of your setup.
Rich
audioengr
« Reply #3 on: 1 Feb 2005, 08:34 pm »
Besides the capacitance problem mentioned, there can be transmission-line reflections that aggravate the response of the driver.  This effect depends on what the driver configuration is at the preamp output and whether there is gain-control feedback on this stage or not.  Usually, if there is a series resistor there, this effect is minimized.
Paul L
« Reply #4 on: 1 Feb 2005, 10:22 pm »
ryno,
Our F.T.Audio Little Wonder Passive Controller has two preouts since day one.
ryno
« Reply #5 on: 1 Feb 2005, 11:28 pm »
Sorry about this question, it's prretty vague. I'd love to do a ack dac and a bottlehead or similar tube pre, but it's for a bedroom system and a battery dac and tube pre are not the best choices. And I'd like to keep the option of a xover eq for the sub.
Hi Paul
I saw your web site for the little wonder, looks nice, maybe a little much in features and price for my little system. In this unit are the two preouts just a split from one, or is there something else inside that makes this work better.
Thanks for responding, Ryan
Paul L
« Reply #6 on: 2 Feb 2005, 12:52 am »
ryno,
It is my buddy Fred's design X-coupler that different from the traditional passive.
I have been running powersub with main amp for a long time.  One of our customer even run biamping as well as a powersub, so practically is triamping.  He biamps with a y-cable through one preout and the powersub from the second preout.
