0 Members and 1 Guest are viewing this topic. Read 6362 times.
AudioEngr, thanks for the feedback. I stream off a NAS via Ethernet, using Roon, to a Bryston BDP-2 streamer. So, I'm not sure what you mean regarding reclocking externally. Is that a device that sits between the streamer and the DAC? I'm under the impression the Antelope DAC has an unusually good clock in it... I think is was considered cutting-edge 7 years ago. If it was 'good' then, would it still be considered good now (relative to the DAC's you suggested)? Would a an upgrade make a noticeable difference?
MrEssenguie,My music is mostly 92k, though I think I have 100 or more albums that are 192k, maybe even higher. I purchased 2gB from a guy. I'm sorry to say I don't know the specs on my Antelope Gold DAC well but it's got the Voltikus power supply, etc. As for my upgrade budget... I find if I'm convinced of something's value the cost becomes somewhat secondary. I know that's vague. But, that disposition helps me avoid skimping.
Thank you, Mike,As my newest DAC is limited to no more than 96k, I won't suggest it for your consideration. If I weren't necessarily concerned about budget, my first suggestion would be to give a Lampizator Atlantic a serious listen. It is <very> expensive, but it sounds wonderful and it can handle hi-res and DSD music. I've got a buddy in the Seattle area who owns one and I've heard it in his system and mine. I very nearly bought a used Atlantic. My next suggestion is to talk to Alvin at Vinshine Audio (in Singapore) about auditioning a Denafrips Terminator. [AC member, Jriggy, is selling his in our trading post right now.] This is another DAC that I very nearly bought for myself. Approximately 3 years ago, I thought I wanted a DSD capable DAC because that's where all the progress was (or so I thought). With that idea in mind, I bought a Gustard X20u DAC from China. It was much better than my old DacMagic Plus, but it wasn't particularly warm sounding. About a year later, I 'discovered' R2R DACs and DACs designed around the old TDA1543 chip....and I fell in love. My newest DAC is a SW1X NOS DAC III STD designed around the TDA1541 chip. I can't imagine not having it in my system - ever! It does everything right for me in my system. Alas, it maxes out at 96k, so it doesn't really fit your needs.I have great respect for Freo-1's equipment opinions, so I would give the Benchmark DAC-3 a try. I have not heard it, so I have no opinion about it myself. I would also suggest auditioning the PS Audio Direct Stream DAC. I heard it a few months ago in an incredible system in Taiwan. Unfortunately, all the components in that system were new to me - along with much of the music that was played - so I can't tell you the impact the DAC had on my experience.I'm a bit of a dinosaur because nearly all the music I listen to is Redbook CD quality. My DAC III excels at CD quality music.As much as possible, take your time and audition as many DACs as possible before you plunk thousands of dollars down for a new DAC. Make sure it makes the music you love to listen to. It's so easy in this hobby to buy a component that you think is 'it' only to realize a few months later that it's not actually what you want in your system.Enjoy your journey. Take your time, and have fun!Michael
MichaelAre you telling me the nearly 6K SW1X NOS DAC STD does not play DSD or hi-rez music(192K) ? man you just broke my heart ! As strange as it may sound I have been debating wither to spend $ 750 bucks on upgrading my Schiit Gungnir delta Sigma DAC to R&R DAC ( used with my desk top HP amplifier )or just put that money towards getting a new DAC ? I did upgrade my PS Audio Directstream DAC well if you call putting in audio magic ultimate Beewax fuses upgrade ! courtesy J. "Ketcham" who got me hell of a deal on those fuses the AM fuses did make a huge difference in my QS mono's ! to my surprise .!!! By the way just love the new mod's made to the DS-2 , you should definitely go for it ! Asghar
If you are using USB to the DAC, then I highly recommend a SOtM tx-UltraUSB reclocker. If you are using S/PDIF coax, then the Synchro-Mesh reclocker. These both insert in-line with the respective cables.Clocks have improved radically over the last 5 years, but it's more than just the oscillator that makes the jitter low. It's the DAC interface design.Steve N.
I find the quality of the original performance and recording techniques make much more difference than the digital format being used.
And consider the source of hi-res files. Nearly all are upscaled from analog or Redbook...
The DirectStream Senoir is no longer made either, unfortunately.
