Is a DAC upgrade worth it?
0 Members and 1 Guest are viewing this topic. Read 6363 times.
TomS
Re: Is a DAC upgrade worth it?
« Reply #20 on: 25 May 2019, 11:32 pm »
The Directstream Sr. is available for far less than $6000 from multiple sources.  You pay list price only if you buy direct from PSA.
Or this one for sale in the trading post 8)
https://www.audiocircle.com/index.php?topic=164040.msg1744326#new
OzarkTom
« Reply #21 on: 26 May 2019, 12:43 pm »
You will hear a difference. I had the Antelope and it was not bad, just a tad anylytical. I personally would not spend a lot of money on a new DAC. The cheaper ones are sounding better and better. I now own a Bluesound Node 2i, and for $500, it sounds very good for the price. I have also owned several DAC's costing $3000 and more. I do not miss any of them.
You can buy one from Music Direct and return it in 60 days if you do not like it.
