Obsession vs HP Digital American for DAC
0 Members and 1 Guest are viewing this topic. Read 2565 times.
pursuitofnow
« on: 5 May 2019, 04:14 pm »
I'm currently using a HP Digital American with my PS Audio Directstream Dac and wonder what differences there would be, if any, by upgrading to the Obsession?
Triode Pete
Re: Obsession vs HP Digital American for DAC
« Reply #1 on: 7 May 2019, 01:22 pm »
Both are superb choices for your PS Audio Directstream DAC.
The "Obsession NCF", with the crazy expensive FI-50 NCF series of connectors ($385 & up EACH!), has 20% more conductors than the already beefy "High Power Digital American".
The "Obsession NCF" will provide a bit more deeper bass response and a bit more airy & effortless highs, while still remaining balanced. Depth of recordings will appear deeper & wider, while still focused...
I hope this helps...
Pete
pursuitofnow
« Reply #2 on: 7 May 2019, 02:13 pm »
Thanks, Pete. That does help. I now see why you named it the Obsession  :)
