N3TL Build
0 Members and 1 Guest are viewing this topic. Read 3581 times.
Kristian105
N3TL Build
« on: 11 Mar 2019, 12:50 am »
Just getting around to building my n3tls i picked up last year.
Kristian105
Re: N3TL Build
« Reply #1 on: 14 Mar 2019, 11:17 pm »
I had time to route the baffles today.  I decided to front port mine.. but upon fitting the baffle I realized brace c is directly behind the lower woofer.  Not sure if I should remove it or notch it out.  I was also thinking of adding a 1” brace under the wooofer to brace the baffle if I remove it.  Dunno if that will affect the sound or not.
Peter J
  • Hmmmm
Re: N3TL Build
« Reply #2 on: 15 Mar 2019, 12:55 am »
I've never built these, but was curious so looked at plans on Danny's site. It doesn't show a "brace C". Is that unique to front port?
I assume the line itself (braces) would be reversed somehow. I think there are several here who have built them, though, so probably best to defer to them or Danny. Don't think it'd be wise to leave it in, should be easy to remove.
Kristian105
Re: N3TL Build
« Reply #3 on: 15 Mar 2019, 01:03 am »
It’s in the blueprint that comes with the kit.  Danny said it wasn’t critical in the build.. but I goofed adding it.  I was originally going to rear port it and changed my mind last second without thinking.  The supplied blueprint clearly shows it in the way if you want to front port it.
I can’t wait to hear them.
grimace
Re: N3TL Build
« Reply #4 on: 15 Mar 2019, 12:01 pm »
Looking good.  I love my pair.  Mine are ported in the back and I have them pretty close to the wall (8") and they sound great, especially with a servo sub.  Sometimes I will pull them out into the room if I'm doing a long listening session, but the difference is pretty minimal to me.
So, if reworking the port to the front is causing you problems, you could probably reconsider.
Kristian105
Re: N3TL Build
« Reply #5 on: 15 Mar 2019, 12:20 pm »
I unfortunately I already glued on the other side, so I wouldn’t be able to roundover the backside of the holes.  I think loosing the brace would probably be less impactful acoustically.
Re: N3TL Build
« Reply #6 on: 15 Mar 2019, 04:17 pm »
I build  a  front vented pair of these a number of years back (man, where does the time go ? ),   left out that  top brace when flip flopping the TL as well
Youi'll love them.
https://www.audiocircle.com/index.php?topic=108845.0
jay
jn316
Re: N3TL Build
« Reply #7 on: 15 Mar 2019, 05:42 pm »
Youi'll love them.
jay
You've come a long way, Jay. Just skimmed that thread and you were pretty much a novice. Now, you are building cabinets for Danny! Well done.
Gary
mlundy57
Re: N3TL Build
« Reply #8 on: 15 Mar 2019, 06:00 pm »
I've done that before. You can still put the roundover on the backside. To do this you need a roundunder bit and a large baseplate on your router for stability.  I used a piece of phenolic material to make the baseplate but you can use plexiglass or even plywood. You want the baseplate large enough to be stable when the bit is all the way to one side of the driver opening or the other.
Here's a roundunder bit. Notice the bearing is on the opposite side of the bit from a roundover bit.
Mike
Kristian105
Re: N3TL Build
« Reply #9 on: 15 Mar 2019, 06:31 pm »
Wow thank you, I didn’t know those bits existed.  That’s very useful information.
Danny Richie
Re: N3TL Build
« Reply #10 on: 16 Mar 2019, 04:54 pm »
Mike beat me to it.
The radius on the back side is very important. If not then it will add a little bump and dip to the response.
Kristian105
Re: N3TL Build
« Reply #11 on: 16 Mar 2019, 10:57 pm »
My solution to the brace issue..
And the start of the crossovers.
I’m going to mount the crossover to the back wall with screws and a layer of butyl tape.
Kristian105
Re: N3TL Build
« Reply #12 on: 18 Mar 2019, 09:48 am »
Crossovers are in and wired
Also began adding the no Rez..
I did a stupid rounding over the backs off the woofer holes on the baffles and now I have to go pickup more mdf and build a new baffle.  I’m annoyed because I made a special trip for this mdf, it’s much nicer to work with and much more consistent than the mdf at Home Depot.  Lesson learned.  Don’t rush.  If you are very tired, you probably shouldn’t be working with power tools.
Re: N3TL Build
« Reply #13 on: 18 Mar 2019, 03:35 pm »
If you  can find it, get  some  Medex.
Nicer to wrrok with, more moisture resistant, and  dimensnonally stable,   less prone to edge  damage.
We use it in many of our  flat packs and builds  now
jay
mlundy57
Re: N3TL Build
« Reply #14 on: 18 Mar 2019, 04:25 pm »
jay
Jay,
Do you have to special order Medex? I've never seen it available in my area.
Mike
Re: N3TL Build
« Reply #15 on: 18 Mar 2019, 04:38 pm »
Jay,
Mike
With certain sizes we do but   we do have a local supplier that stokcs  .75" .    With  1"  and  1.25"  we usually bring  in   a few sheets of each at a time.
jay
Kristian105
Re: N3TL Build
« Reply #16 on: 22 Mar 2019, 08:50 am »
What is the best way to install the tweeter cups?
Thank you for the Medex suggestion, I found a supplier about an hour out from me.  Maybe I’ll pick some up for the next build.
mlundy57
Re: N3TL Build
« Reply #17 on: 22 Mar 2019, 01:19 pm »
Could you add more detail to your question. The shour answer would be “with the supplied screws” but I think you might be asking something else,
Mike
Kristian105
Re: N3TL Build
« Reply #18 on: 23 Mar 2019, 03:34 pm »
How do you attach this?
Re: N3TL Build
« Reply #19 on: 23 Mar 2019, 04:04 pm »
Some 5 min epoxy  will  do the job just fine.   You could even hot glue it.  Won't  fall of  with  either
jay
