N3TL Build
0 Members and 1 Guest are viewing this topic. Read 3505 times.
Kristian105
Re: N3TL Build
« Reply #20 on: 23 Mar 2019, 05:14 pm »
Thank you, wasn’t sure if I was missing something.
Today I’m testing and fitting.. getting ready to close the box
Kristian105
Re: N3TL Build
« Reply #21 on: 23 Mar 2019, 06:27 pm »
Will a 3/8 roundover on the front baffle make a noticeable difference in response?
mlundy57
Re: N3TL Build
« Reply #22 on: 23 Mar 2019, 07:17 pm »
Most folks put a 3/8" roundover or larger on the front vertical edges. The roundovers actually help the sound by reducing edge diffraction. The larger the radius the more the improvement. I usually use a 3/4" radius. The larger radius also makes rolling veneer over the edges easier, which tends to be why I use it.
You can round all the edges over if you want too. That will also help control edge diffraction at the top and bottom as well as the sides.  This won't work if you plan on veneering the cabinets because you can't roll veneer in more than two planes, unless you use a modified method. If you are going to use paint, a roll on finish like DuraTex, or use thick enough pieces of solid wood you and roundover all the edges if you want.
Mike
Kristian105
Re: N3TL Build
« Reply #23 on: 30 Mar 2019, 05:19 pm »
A 3/4 inch round over doesn’t take away too much material?
Peter J
  • Hmmmm
Re: N3TL Build
« Reply #24 on: 30 Mar 2019, 05:46 pm »
No worries. Regardless of corner construction, there's plenty of strength.
