0 Members and 1 Guest are viewing this topic. Read 4022 times.
Thanks, Phil. I see based on your recommendations, I need to add more info. (Hmm...too bad I'm at work, or I'd take a picture of the system to help people visualize this.)I need a stand that both houses the center channel and upon which a 53 inch (I think?) TV will sit. So, I need a piece of furniture with a top, flat surface to hold the TV, and then underneath that, another flat surface to hold the center channel. I'll see if I can take a picture of the system as it currently is, but that might not be until this weekend.
This is the old TV stand (Ikea), which is great, but note the lack of space to put the massive HT3 center channel:
We had a similar issue with trying to find a home for the SS7C. We had a number of limitations/constraints on placement and furniture, and needed a place for the 65" plasma.The end solution was to draw up a workable design with weight limits and specs, take it down to my local welding shop and have them build out a nice aluminum frame. Had that powder coated, added some nice thick maple butcher block shelves, and some industrial ball casters. It's worked out well.Turned out to be way cheaper than most of the commercial solutions and incredibly sturdy. - Ben
