0 Members and 1 Guest are viewing this topic. Read 4339 times.
Excuse my ignorance here but,1- Given a speaker could be tri-amped : Should I get similar results if using a 6 channel amplifier or 3 stereo amplifiers from a similar brand with equal specifications for power, impedance, etc...?2- Given I could Bi-amplify : Is it the same to use vertical or horizontal amplification?I'm not sure about this questions but a friend has his speakers bi-amped with a 5 channel amplifier ( ATI 2505) and he said he used them that way for convinience.... Jose.
Gracias Doug.I apreciate your help.BTW.... Our audio friend, the Psychicanimal is still in PR and searching for a new local job. I believe he will stay if he find something soon, if not, he will go back to Florida ( his last home...). Jose.
What's the difference between vertical and horizontal biamping? When I biamp my speakers, I split the signal, send it to one amp which drives the mids/highs, and send it to another amp that drives the lows. Is this vertical biamping?
I still don't understand. I've done the following: I split the signal from my preamp. The right signal is split into two signals, R1 and R2. I took R1 and used one channel of my five-channel amplifier to power the lows of one of my RM40s (the right RM40). I took R2 and used one channel of my two-channel amplifier to power the mids/highs of the right RM40. I did the exact same thing for my left RM40. I did this for a while. Now, I split my center channel output into two signals and amplify both of them using channels of my five-channel amplifier. Is this still horizontal biamping?
Quote from: ctviggenI split the signal from my preamp. The right signal is split into two signals, R1 and R2.Do you have 2 sets of outputs, or are you using a splitter as it sounds like from your post? Does this work ok without degrading the signal? Someone I know would like to use 2 identical stereo amps as monoblocks which he could do by vertically biamping, but he only has one set of preamp outs.
but, you do have to be careful of the impedence matching. splitting the preamp output is equivalent to doubling its output impedence. and your preamp's output impedence shouldn't be more than 10% of your amp's input impedence
Quote from: doug s.but, you do have to be careful of the impedence matching. splitting the preamp output is equivalent to doubling its output impedence. and your preamp's output impedence shouldn't be more than 10% of your amp's input impedenceHmmm..well since the two amps in question are almost identical but do in fact have different input impedances I guess that would do away with the "monoblock" idea and force horizontal biamping as the best option. Either way it would still require a splitter like you linked.Thanks for the tips.
i am curious as to what amps you have that are "almost identical", but have different input impedences.
I don't have 2 of these, but I'm referring to an original eAR amp and one that has been upgraded with Peter's modified modules that add short protection and up the input impedance from 7.5k to 50k. As far as I know the other specs like sensitivity and gain are the same (unless whatever circuit changes that increase the i.i. mandates something else change). I think they would work fine horizontally, but I would be concerned with the impedance match on the older amp with the splitter, although the person is using a SS pre so I think it would be fine.
