DAC-9 Rca out to Sub
0 Members and 1 Guest are viewing this topic. Read 3457 times.
djlotfi
« on: 8 Nov 2018, 05:36 pm »
Hello ,
i am new and happy user of a Dac-9 , outstanding quality , but the sound coming from my subwoofer is verry low ,my sub is SVS 1000PB   plugged to the RCA out of the DAC-9
volume on the sub is on maximum and still  barely hear it  , anyone can help with that ?
rustydoglim
Re: DAC-9 Rca out to Sub
« Reply #1 on: 8 Nov 2018, 05:43 pm »
can you sub take XLR ? XLR by design has double the voltage of RCA.
djlotfi
« Reply #2 on: 8 Nov 2018, 05:52 pm »
The svs 1000 have no  XLR in    :(
rustydoglim
« Reply #3 on: 9 Nov 2018, 09:19 am »
I know our line out has industry standard gain (2V?) so did you get your sub from a system and might have designed for its preamp/sub output.
RafaPolit
    • www.rafaelpolit.com
« Reply #4 on: 9 Nov 2018, 12:29 pm »
How is the rest of your setup?  Are you going to the sub and from the sub out to an amplifier?  Are you using the RCAs for the SUB and the Balanced to the AMP?
Did you connect both RCAs?  Your subwoofer can take either one RCA carrying a LFE signal (created by an AV receiver, for example) or a full range RCA be connecting both RCAs.
You need to use both on your case, as the DAC-9 is not generating an LFE.
If you could elaborate more on your setup, it would be a bit easier.
Mariosavu
« Reply #5 on: 6 Dec 2018, 09:14 pm »
Hello, I have the same issue with my REL9. The rca out from Dac and low level input from Rel is to low.
I have to connect to STA 9 the sub, High Level input but I don't like this solution. Any iddea?
JackD
« Reply #6 on: 7 Dec 2018, 03:15 pm »
Agree with Rafa.  Make sure you are using the Line input, which is expecting a fixed input level, as opposed to the LFE input which has a lower input sensitivity as it expects you to have the ability a raise the level yourself on the source side.  Also if you are using single sub with only one line input from a stereo output source you will have to buy a 2 to 1 adapter to sum both outputs from the DAC-9 and if the sub has two inputs you will have to attach to both. The DAC-9 and DAC-10 have no problem driving subs.
simon740
« Reply #7 on: 31 Jan 2019, 12:39 pm »
Hello everyone,
Im a happy owner of DAC 9. I use XLR out to my Sonodyne SRP 205 (SRP 800).
Now Im thinking to add some REL woofer. One T7i or 2x T5i.
So can I use both output (XLR and RCA) at the same time?
XLR to active speakers and RCA to active woofers?
regards,
Simon
John Casler
« Reply #8 on: 31 Jan 2019, 10:15 pm »
Hello everyone,
regards,
Simon
Yes, both RCA and XLR are active concurrently.
« Last Edit: 1 Feb 2019, 03:00 pm by John Casler »
simon740
« Reply #9 on: 1 Feb 2019, 08:57 am »
Yes, both RCA and XLR are active at the concurrently.
Thank you
regards,
Simon
