...I'm still trying to understand if the tube or the way the tube is fed by the amp is the Watt-determine factor, it would be great if someone here could enlighten me on this ^^) ...
I have the junior 8s with a Decware Zen 2 wpc. My room is midsized and I have no problem getting too loud.
Here you go..https://www.usaudiomart.com/details/649477295-single-ended-45-triode-amp-set-dht-korneff/45 goodness and won’t break the bank Dwight
I have to get in on this. I have a couple pairs of Omegas and a couple amps, including a 45 Korneff. I used the 45 with great results. Just not perfect. It sounded SO good I just wanted to keep turning it up and it didn't have enough to get it where I wanted to go.
While I am not currently an Omega user, like Happy Rabbit, I am an Oliver Sayes clone amp fan. Last year, Oliver sent me his Yamamoto A08 clone which has been my reference all year. My 94.5 db speakers were the only limitations to power, but the Sayes clone pushes well above it's cost in moderate listening levels. Recently, Oliver sent me a Garber 421a clone using UTC iron and it has really opened my eyes. Adding 2.5 more watts to the Yamamoto's 2 watts, the 421A amp adds more body, clarity, and especially more mid bass than the Yamamoto. My 24' x22' listening room is heavily acoustically treated, so both the Yamamoto and 421a amps can extend the soundstage width the entire 24' width with very deep soundstage off the front wall. The downside to the 421A amp is the 421A Tung Sol/Western Electric tube is becoming scarce and expensive. Art Dudley and 6Moons did rave reviews of the Garber 421A amp years ago, with 6Moons comparing the Yamamoto and Garber.
Roscoe,6Moons, Sragan Ebean's comparison review of the Yamamoto A08, Garber's Fi 421A, and Canary 300B amps really hit the nail on the head for me. His comments about the Yamamoto and FI differences convinced me to take a chance on the Oliver Sayes 421A clone. Like you, I have the Western Electric and Tung Sol 421A tubes and they are very similar, but the Western Electric has slightly better bass and alittle more warmth. Since Oliver uses different vintage iron from amp to amp, the slight sonic differences may result from the changes he makes amp to amp. My recent communication with him suggests he likes the 421A enough that he is also searching for more 421A tubes. He also likes the Yamamoto as well. The sonics of the 421A are close to the 45s but not quite as sharp and incisive. The Yamamoto is race horse like, very fast, and should mate very well with Omega's smaller drivers while the 421A is slightly slower and with the addtional bass and power maybe a better candidate for the bigger drivers like the Junior 8. Both amps are very quiet for tube amps. The Yamamoto's honest 2 watts are noticeable compared to other 45 amps that I have been exposed like Korneff, Music Reference, and others. The Yamamoto just sounds more powerful when compared to other 45 amps in my experience. I like both amps enough that they will stay in my system. My best advice is read the 6Moons review carefully as Srajan details the sonic differences between the two amps very well. 6moons.com/audioreviews/fi6/421A_2.html
