0 Members and 1 Guest are viewing this topic. Read 6266 times.
Suggest you ask Wendell about that. The Tympani IVa was designed to be used either way, with the mid/tweet panel separate and the bass panels against the side wall, or with all three panels in line and the speakers freestanding.
Heh, yes, if you do that with a Tympani, you'd better be prepared to EQ it down. But you get more headroom once you do.I've also found as you do that a few inches can make a big difference.I mentioned your post to Wendell, BTW, and he said he hopes you call. I'll be curious to hear what he says if you do!
