0 Members and 1 Guest are viewing this topic. Read 10450 times.
About $1300 installed for the pair
I would not do it. $1300 is no small change for an amp of that vintage. You can easily surpass the performance of those amps with buying newer amps add some more hundreds to your budget. Class D has come a long way from the time when they were sterile and hollow in quality.
Yeah, I will echo what JLM and Bemopti123 said. For less than half of that you can buy a very serious amp.https://www.audiocircle.com/index.php?topic=158669.msg1694846#msg1694846Class D has arrived in a very big way; the amps I have now easily surpass all the tube amps I’ve owned over the past 30 years.
