0 Members and 1 Guest are viewing this topic. Read 10458 times.
No, it’s not class D, but I bet it’s a far more sensible option to putting $1300 into a vintage amp.
I'm having a little trouble with folks calling these vintage amplifiers. They aren't from the 1940s-50s. Also, they've been substantially upgraded/modded (except for the power supplys apparently) by a knowledgeable equipment designer/builder. I appreciate that class D (or chip amps) is the new flavor of the day in amplification, but I don't think class A and A/B amplifiers are dinosaurs. In 20 years when the current class D amps become "vintage" will they be maintainable/repairable, or will they just be thrown in the recycling bin?
Hi Guys: I've had several mods done to gear I've owned in the past and to tell the truth I found it hard to tell the difference between stock and mode. Cheers Charlie
Just for fun, here's my two early 555's, 1986 models, still in perfect working condition. After 32 years it's time to replace, at the very least, the lytic caps before they leak like my turntable......
I compared my Adcoms with two others unmodded. And 6 out of 6 in a blind taste test picked the modded ones each time. There was a significant difference in them. I even tried to fool them. They still picked the modded 565’s. Just not sure if the next mods will be worth the gain. Anyone know of a solid 300 watt per channel into 8 ohms or 850 watt at 2 ohms per channel class D amp that can drive manepans without breaking a sweat? I haven’t seen to many amps that can drive the Maggie’s as well. The Krell KSA 250 even fell short compared to these 565’s. I am going to demo an AVA Fet or Set amp. I think Franks Amps are built with as much drive as these have. I’ll fine out soon I think. I have demoed a ton of amps. None have been able to drive hard 4 and 2 ohm loads like the 565’s. This is were these amps shine. Here is an article from StereophileOn a review of the 565’s. These are just stock ones. Adcom had a great circuit with good parts in some places. And cheap in others. When you replace the cheap ones. These amps really come alive and loose the harshness and grain people complained about. They are tight, fast, very hard hitting, clear, with awesome 3d imaging. With little to no coloration. And they are dead quite. Which is great for a high current amp. These are unlike any other Adcoms ever made.https://www.stereophile.com/solidpoweramps/adcom_gfa-565_monoblock_power_amplifier/index.html
H2o 250 Signatures have driven my mom's Kappa 9sYour Mom?How cool is that?
