0 Members and 1 Guest are viewing this topic. Read 4388 times.
These are active, correct? Would you recomend them for both systems?Also, do these units provide isolation between components?
these are active - will offer sonic benefits, but not equipment protection. they will not provide isolation between equipment, but they are cheap enuff so that you can get one for each piece of equipment. but, i would suggest that the only digital equipment absoluutely needs separation from the rest of your gear. ie: one iso tranny each, for cdp, & dac; another for everything else. if you have a one-box cdp, then ya only need two total. only caveat - if you use one for your amp, it has to be big enuff so as not to choke the amps' dynamics...doug s.
Doug: Why do you say the Powervar and Oneac conditioners won't protect your equipment. They should protect it from anything short of a lightning strike. There are Pi filters for noise, surges are diverted to ground and an isolation transformer.
One thing I must correct in common misperception is that adding a dedicating line protects one's equipment from noise within one's own house and this is simply not true as all the lines in the house are still in circuit with one another. However, there are still some advantages to be had from dedicated circuits, and there may be some ...
