Please help with SP1.7 Problem
0 Members and 1 Guest are viewing this topic. Read 2240 times.
TT9
« on: 9 Jan 2005, 10:07 pm »
Hello everybody, I have stumbled across this excellent looking forum while trying to find an answer to my problem. I hope someone can help me!
Has anyone tried feeding an SP1.7 digital signal via Perpetual Technologies little P-1A ?
I have taken a Bryston SP1.7 on loan having given back an MC-12B which I did not like. I enjoy my SST power amps so hope the 1.7 is for me also. Anyway, for Digital Music listening, I use a DVD32R transport, the Perpetual Technologies P-1A upsampler, and then the digital input into a processor. Ultimately I will be getting a Dan Wright Sig2 P-3A but thats another subject.
Anyway in the mean time, I have a small problem with this combination. If I set the sample rate on the P-1A to 96Khz, the display on the Bryston correctly shown the incoming signal as this, but there is no music, only a nasty pink noise. If the sample rate is set as 44 or 48, these numbers are also correctly shown and the music is fine. I have tried experimenting also with the bit density but it doesn't make any difference at the 96Khz rate. At the two lower sample rates, I can output the full 24bits without problem, but nothing at 96 seems to work.
Is something faulty or is there a reason why this would not work ? Does anyone know enough about the SP1.7's internals to be able to offer an explanation why this should or shouldn't work ?
I have this working fine with my old AV32R and the borrowed MC12-B.
Thanks and Regards,
Steve.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 10 Jan 2005, 10:38 pm »
HI TT9,
What version of software do you have in the SP1.7 or give me the serial number.
james
TT9
« Reply #2 on: 11 Jan 2005, 09:12 pm »
Hello James,
Thankyou kindly for taking the time to repsond.
The firmware is verison 41 I believe. This is the message I get from the display upon startup. I have not checked the serial as is all nicely in rack but if essential I can unplug and look for you.
May I ask you something else as well ? If I stop my dvd player, and then open the tray to remove the disk, there is a very audible 'pop' sound from the speakers. I have searched previous posts and believe this was an identified problem ?
Also can I just add that I am very pleased with this machine. I have a 4BSST and 9BST, and PMC OB1's actually so I think I will be ordering my SP1.7 when my demo unit has to go back. Is so much more musical than the Lexicon, I thank you.
Best,
Steve.
« Reply #3 on: 11 Jan 2005, 10:38 pm »
Hi Steve,
The 41 is quite old so the new software (44D) will solve the issues you have been having.
Thanks for your positive comments regarding the sound of the SP1.7. I get about 2 callers a week telling me that they had such-and-such a processor in their system - replaced it with the SP1.7 and can not believe the increase in quality of sound.
james
Levi
« Reply #4 on: 12 Jan 2005, 06:00 am »
Hello TT9,
I have auditioned a Lexicon MC12b in my home and Bryston SP1.7 clearly sounded more transparent in 2ch by-pass mode.  The pop you are hearing possibly is coming from the source.  I would try a different source and see if the "pop" is still there.  If so, James already has a solution for you.  You will need a high quality Robertson bit.  The aluminium fasteners are easy to strip.
Levi
jradley
« Reply #5 on: 13 Jan 2005, 12:51 pm »
Quote from: Levi
Levi
I'd agree - I mushed up the head of one of the screws on my SP1.7 when attempting to upgrade mine to 44D. I'm still wondering what to do about it.
If I can get to the Bristol HiFi show here in the UK at the end of Feb I'll see if I can chat up the PMC guys and see if they might take it off me and see what they can do - I'm a bit scared at what they might charge though.
Coincidently it was to avoid the same pop that I was attempting to upgrade my unit.
Enjoy the SP1.7 - it is a fine pievce of kit.
John
« Reply #6 on: 13 Jan 2005, 01:15 pm »
HI John,
You need a"Green Handle Robertson" screw driver to get the screw out.
james
TT9
« Reply #7 on: 13 Jan 2005, 01:49 pm »
Guys,
Thank you all for your support and advice on this thread. I have decided definitely to purchase a new SP1.7 and have informed my local dealer to start the wheels turning with PMC and acquire me a new one.
Those years ago (about 3) when I bought my AV32R, nice machine it was and gave me lots of listening pleasure, if I'd slackened my wallet only a little bit more and gone for the Bryston then at that time I would have saved myself this whole merry-go-round. .  :P
Anyway, I definitely feel I am moving up onto a higher audio plane, so it's all got a happy ending.
Best,
Steve.
TT9
« Reply #8 on: 13 Jan 2005, 01:56 pm »
Guys,
One last thing please. For my curiosity, would anyone have a link or some documents which details the changes and additional features between each of the software versions between say 41 -> 44D. Am interested to see.
Best,
Steve.
