0 Members and 1 Guest are viewing this topic. Read 22569 times.
You turn your hifi off?dave
Not a valid generalization. Depending on the box and the driver in the box, too high a damping factor can overdamp the driver.Having lived with a variable transimpedance amp (output impedance controllable from near zero to near infinity), each speaker we tried had a different optimal setting.dave
Yep. I just can't see spending $320.00 for output tubes every year or two. Driver and preamp tubes add another $100.00. Add electric bill for AC etc in the summer and ouch.cheerssteve
Steve, I can't imagine anyone in their right mind leaving tube gear 'always on' , especially power amps.
To me it is significant that both of the people who, to my knowledge, have spent the most time actually listening to the effects of different materials and configurations used in conductors and elsewhere in the system (Denis Moorecroft of DNM and Pierre Sprey of Mapleshade) have settled on small diameter, single conductor cables as optimal.http://www.mapleshadestore.com/speakerwires.phphttp://www.dnm.co.uk/materials.htmlResistive power loss is compensated by a miniscule adjustment of the gain control, is it not? The reduced damping factor effects caused by higher cable resistance may well be less audible than smeared arrival times and distortion caused by diodic effects and other effects resulting from multistrand cables. Also the added resistance would be trivial when compared to the output impedance of the typical tube amp, wouldn't it?
Well, I'm not . . . ...convinced about the benefits of solid core wire. In fact, just the opposite. I used s/c wire in my GR Research LS-9s to begin with but was put off by a "whang" sort of effect in the midrange and treble. I replaced it with (damned) expensive) Marigo wire (Litz configuration) and experienced immediate relief. Sounds wonderful now.I know what you're thinking: "I thought it was going to sound better; therefore it did." But my hard-headed audio buddies think so too.S/C wire is fine for subs, but not (in my system/experience) mids and tweets.
It appears that your findings agree with ours in that each system, venue etc is unique. Was that just one wire, or multiple that the OP, me, and others tested in our systems.cheerssteve
It's a simple fact. A science and math thing, not an opinion. It's like a dog on a leash, the shorter the leash, the more control over the dog.
Higher damping factor = better, always (:
Thorsten Loesch , formally at TNT Audio mag, am ultimate tweekster and now the designer of AMR and IFI electronics says this about speaker wires.http://www.tnt-audio.com/clinica/spkcbl_e.html
Seriously, throwback's speakers are LS9's!!! Mine's just a two driver two way. Comparing apples and oranges perhaps?
It's a simple fact. A science and math thing, not an opinion. It's like a dog on a leash, the shorter the leash, the more control over the dog. Higher damping factor = better, always (:
