First board I've joined.
0 Members and 1 Guest are viewing this topic. Read 1263 times.
mariospeedwagon
« on: 30 Apr 2018, 01:04 pm »
Hello,
I started enjoying vintage stereo equipment for about 5 years now and have a pretty decent setup at the moment.  Looking for recommendations on an equalizer and do not know if an expensive unit is the way to go. I am huge in to vinyl and my speaker setup has a lot of sub-woofers and trying to balance it all out.
Mario Speedwagon
Re: First board I've joined.
« Reply #1 on: 30 Apr 2018, 02:18 pm »
Greetings & Welcome to AC Mario Speedwagon    :thumb:  Any relation to REO ?  :wink:
Phil A
« Reply #2 on: 30 Apr 2018, 02:25 pm »
Welcome!
Blackmore
« Reply #3 on: 30 Apr 2018, 02:37 pm »
Welcome and we’re glad you’ve joined us at AudioCircle.
mresseguie
« Reply #4 on: 30 Apr 2018, 02:44 pm »
Welcome to AC, Mario.
Michael
« Reply #5 on: 30 Apr 2018, 03:07 pm »
Welcome Mario.
Have you found Audio Kinesis here at Audio Circle (child circle)?  Duke LeJeune speaks a lot about setting up multiple subwoofers (swarm is what he calls his offering).  Read Floyd O'Toole's "Sound Reproduction" to get a handle on the theory/advantages behind the proper use of multiple subs.  EQ should only be thought of as icing on the cake.  Best to start with a good room (proper size/shape/materials) then add treatments/subwoofers as needed/desired, finally look into EQ or nowadays DSP.  Old EQ units have tons of sliders which are notorious for collecting dust/rust/dirt film.
Note: avoid trying to bring up narrow frequency response dips (for instance a 20 dB dip takes 100 times the power to even it out) which can cause the amp to clip and instantly lead to speaker damage.
JakeJ
« Reply #6 on: 30 Apr 2018, 03:47 pm »
Hello and welcome to AC, mariospeedwagon.  Pictures, please.  Also an entry in the member systems section is always welcome.
dB Cooper
« Reply #7 on: 30 Apr 2018, 05:26 pm »
Welcome to the sweet spot
« Reply #8 on: 30 Apr 2018, 08:46 pm »
Welcome aboard Mario :thumb:
Jazzman53
  • Jazzman's DIY Electrostatic Loudspeaker Page
    • Jazzman's Electrostatic Loudspeaker Page
« Reply #9 on: 1 May 2018, 12:30 am »
Welcome Mario,
You mentioned you are into vintage gear and you're looking for an EQ.  If you want to keep to vintage/analog rather than digital for the EQ, an Audio Control C101 is a very nice 80's vintage unit that comes with a mic, RTA & pink noise generator-- if you can find one they are very reliable and well built.
Jazz
« Reply #10 on: 1 May 2018, 12:49 am »
Most people want a EQ to up the bass, if its the Mario prob, I suggest dont spend cash in an EQ, instead change the speakers internal stuffing, for a first class service remove all the stuffing and before applying the new one paint all sides inside the enclosure with black mate paint and after add the new stuffing.
https://www.audiocircle.com/index.php?topic=100689.0
mariospeedwagon
« Reply #11 on: 5 May 2018, 01:59 pm »
Thank you for that information.
Welcome Mario.
mariospeedwagon
« Reply #12 on: 5 May 2018, 02:06 pm »
Thanks for the link.  The bass is not my problem.  I'm running 2 Sansui SPX 11000's 2 and Kenwood KL 777DX.  I need my mids and highs to come through better.
« Reply #13 on: 5 May 2018, 09:10 pm »
In this case stm you need delicacy and refinement, these speaker wont do it.
Since that time speakers evolve a lot in that area,
