Physical Measurements for BP26
0 Members and 1 Guest are viewing this topic. Read 2135 times.
Yogus
« on: 5 Jan 2005, 05:45 am »
Hi
Does anyone know the height of the BP26 including the MPS-2?
Also, is there a minimum clearance (top and sides) required for ventilation for the MPS-2?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 5 Jan 2005, 03:09 pm »
Hi,
No minimum clearance other than the feet on the bottom.
Each unit including feet is 2.75 inches for a total of 5.5 inches if you stack them.
james
Allezvite
Oops
« Reply #2 on: 5 Jan 2005, 04:26 pm »
Quote from: James Tanner
Hi,
Each unit including feet is 2.75 inches for a total of 5 inches if you stack them.
james
At the risk of being a "smart @$$", I have the benefit of 3 cups of coffee under my belt, so the neurons have been firing for a while and the brain pan is all warmed up.
It is still early in the new year, so James is naturally forgiven.
 2.75"+ 2.75"= 5.5"
« Reply #3 on: 5 Jan 2005, 04:32 pm »
Thanks Allezvite,
As my wife says --- I have always had a problem with measurement
james
Ron D
« Reply #4 on: 5 Jan 2005, 06:50 pm »
heres a monkey wrench...
if the faceplate is actually higher than the top panel of the enclosure then would not the height of the rubber feet of the preamp on top be "absorbed" as part of the measurement? Probably not too clear on my part but the picture of the combo looks like the top plate sits a little lower than its faceplate does and therefore if its true than the estimated total height of both units together is:
fullsize power supply = 2.75"
preamp less the height of the feet, say only 2.5"
for a total of 5.25"
Guess I don't have enough work to do if I'm contemplating this :wink:
« Reply #5 on: 5 Jan 2005, 08:53 pm »
Hi Ron,
Good thought - I will officially measure mine at home tonight and let you know the stacked height.
james
« Reply #6 on: 5 Jan 2005, 10:37 pm »
OK - here it is.
The BP26 plus MPS-2 stacked is 5.25 inches.
The BP26 or MPS 2 on their own is 2.75 inches.
james
