0 Members and 1 Guest are viewing this topic. Read 7674 times.
I have heard many great reports about "DIPOLE" woofers and SubWoofers, but have not heard them. Well in essence a "dipole" sub would seem to be generating a similar radiation pattern, or room loading, except in this case "YOU" are inside the woofer.
I could be way off there, but it seems one of the "downsides" of Dipole Woofage is they don't play very loud and they can't play very low. Well hold onto your Fedora (does anyone know what that is? ) this system will hit the low notes.
John,Did you see the thread in the acoustics circle where we were discussing sub placement? Click HereHarmon has some white papers that basically state that the best sound was by having the subs at the midpoints of the walls (both L/R and F/B).I want to try this, but I am not sure I can do it with my current physical setup (those darn Largers are pretty darn big!)Anyway, glad to hear that your results are consistent with the white paper and what denverdoc reported.George
John,Great stuff. And the midwall front and back postions concur with another thread regarding Harmon Kardon's megamanyear/megasubwoofer study. (Edit: oops, George beat me to it)Couple of questions:Do you run the 626r's full-range? Regardless, what are the Largers crossed at? I'm toying with using subs (probably not my current two Sunfire truesubs, but I'll start with them) for 2 channel listening (with my RM/X's currently) especially when my DEQX arrives. Wondered what you thought the RM/X rolloff will be measured at.....thx,Ted_B
John, I don't generally post in your forum so feel free to delete this if you'd like. I wanted to offer a correction to what you said.
To simulate a diploe woofer radiation pattern with sealed box woofers you would place two of your woofers back to back and drive one out of phase with one the other. I say simulate because this 1) will not exactly produce a figure-eight radiation pattern, and 2) dipole woofers by convention don't use a sealed box (and don't have the associated box resonance problems that plague most sealed designs). You may want to give that a try and see what you think. Your end result may be similar or even better
Playing loud can be a shortcoming if the proper driver isn't used or the "box" is too small. For instance, my dipole woofers are flat to 18Hz in my room. I'm not sure how loud they'll play at that frequency but I can tell you that things start to rumble off the walls before the woofers show signs of giving up.
OK, I don't want to cause Big B's cranium to Hypertrophy any more, but I have to share some of my bass experiments, based on a Cheney set up suggestion of 10 years ago (or more).First off, I several weeks ago ended up with 4 LARGER subs. Now many would say that I'm likely to blow my walls out and I probably could, but my goal was "real" bass.
OK...Now picture THIS...(Will only work with NEO Original, unless you convince Big B to mirror image NEO Larger)...Take 4 Neo Original...2 per channel. Set 'em up on end. Push 'em together. See how you have a by-design front slot firing? Run 1 out of phase...or whatever. Set your 626 on top. Interesting?
Quote from: sfpepperOK...Now picture THIS...(Will only work with NEO Original, unless you convince Big B to mirror image NEO Larger)...Take 4 Neo Original...2 per channel. Set 'em up on end. Push 'em together. See how you have a by-design front slot firing? Run 1 out of phase...or whatever. Set your 626 on top. Interesting?Hi Steve,I'm not getting the "picture". What is a NEO Original?I'm prepared to wear the "dunce" cap (I owe you an e-mail by the way)
Quote from: zybarHarmon has some white papers that basically state that the best sound was by having the subs at the midpoints of the walls (both L/R and F/B).I'll try to read those papers when I get home tonight, but one question jumps to mind immediately... assuming you only have 2 subwoofers, do the papers mention whether midwall left/right was better than midwall front/back?(I realize that this may be room dependent.)Thanks!
I am a little dense. Are you saying the jist of this concept is to have two identical subs with one on the front wall between your main speakers firing in phase and the other sub behind the listening position in the rear of the room firing out of phase?
Maybe I'm the Dunce, in losing the 'vernacular' The sub with the single front firing 12", 15" passive in the horizontal cab is the Neo Original, no?As the Front firing active 12" and 15" w/passive 15" is the Neo Larger?Hell...I've got 2 of the former...lemme know if I'm talking wrong. Aside:You don't owe me anything except your continued outstanding support/advice/and Pricing! (heh-heh) (Cheerios for a great show!)
John, do you have any feel for how much of a reduction in required power per subwoofer you need when using multiple subwoofers? Presumably, it isn't a one-to-one relationship (2x the subs = 0.5x the power/sub), but it has to help. I wouldn't think you need 1000 W/sub any more since each sub will be doing less work...
