0 Members and 1 Guest are viewing this topic. Read 7708 times.
I am actually going in the opposite direction and adding a second Crown K2 to the system. This means a K2 for each Larger sub.I will try the amps as mono amps (about 2500 watts each) and as stereo amps with each channel connected to a single driver.
Quote from: zybarI am actually going in the opposite direction and adding a second Crown K2 to the system. This means a K2 for each Larger sub.I will try the amps as mono amps (about 2500 watts each) and as stereo amps with each channel connected to a single driver.Do the neighbors complain when you play loud passages and their lights dim? Let us know how it works out!
John,Very interesting setup. It's time I get up to your place to hear it. ...
This is a rather interesting discussion since I recently added a sub to my setup. Now, our discussion here assumes that the subs's drivers are front-firing (like the Larger). Does it apply to subs that have downward firing drivers? Just wondering.
john, thanks so much for posting yer impressions of this. as ya know, i have been waiting for info about this ever since ya posted ya got a 2nd pair of larger subs. as the owner of a pair of larger subs that i upgraded to megawoofer status, (i bought these long before megawoofers were an option), i now only need to buy two 15" passives to make a second pair of larger subs... regards,doug s.
Would this method work for a biwired set of speakers? I have NHT 2.5i mains which are crossed over at 100 Hz at the woofer. I don't have them biwired now, but if I did, would I get the same bass affect running the mid/treb in phase and the woofers out of phase?
