0 Members and 1 Guest are viewing this topic. Read 14869 times.
Not so much a question as an endorsement for the following link: http://www.harman.com/wp/index.jsp?articleId=1003I'll try to summarize the article linked: a JBL/Harmon researcher uses computer modeling to determine the best placement for subwoofers in a generic rectangular room, using from one sub to a virtual infinite array in effort to provide reasonably uniform and flat bass FR to a centrally located area which might be used for HT use. Results are then verified w/in reason in a real room with SOTA ...
And, can you tell where the subs are? If so, I don't think I could stand this. I can barely stand it with a single sub behind my RF speaker -- even with level matching and lowering the crossover to 60Hz, I can still easily point out the location of the sub.
by far the most elegant solution involves use of IB subwoofers. I'm putting two in my crawl space which, unless I have misunderstood the specs written up by T. Nousaine in some glossy mags for big players like Genelec and Velo 1812, will out perform in EVERY respect for a fraction of the cost.
So you did midpoint L/R vs. midpoint F/B?Can you post measurements?I thought the article did show that you lost a little output at the bottom, but gained a more uniform response with the midpoint vs. corner placement.I am going to try the L/R midpoint vs my current placement (near the corners, about 39" from the front wall and 24" from the side walls) and see what happens.Unfortunately, I can't do F/B placement since I have my screen on the front wall.George
Too bad, Denver Doc, that you live in Colorado, or I could bring some bass traps to test. If I ever buy two subs (which I'm trying to do right now), I can test your theory with and without bass traps and publish the results. However, I won't actually be able to live with my subs this way, as I have too many openings along one wall and a sub would close off one of the openings (not to mention get in the way).
