0 Members and 1 Guest are viewing this topic. Read 89273 times.
Can't people just, you know, spin a record or something?Computers should be illegal.
That brings up a good question, how does the 1200AS2 sound with vinyl.
You realize you could be setting off a troll war over turntables with that advice.
I don't see how. Everyone knows the best tables are direct drives, with the Technics SL1200 being the pinnacle of vinyl playback.
Here's a few impressions I posted yesterday:These threads are so convoluted and digressive it's difficult to find the listening impressions.
Yes. Not that it was a forum mainly audiophile.In any case I will update the first post as others manufacturers appear and there is more information about the current ones.
120 on a pallet. If they sold 120 and only have 30 coming, it's going to be an issue. Especially since Icepower know's what they're up to now.
I've been thinking about these 30 Takachi cases I have with holes pre-cut for the Icepower 1200S modules, and what I'm going to do with them. I was going to save them for later, but I'm thinking now why sit on inventory? So I decided to sell them off as completely assembled 1200AS amplifiers. They will all only come with my standard level cables and connectors. This includes Neotech OCC copper input and speaker cable, Neutrik analog input connectors, CMC pure copper binding posts, and Mil spec silver plated copper power cable.Pricing will be $899 for silver, and $939 for black. Contact me on my home page for more details:https://www.miveraaudio.com
You don't pay tax on the shipping cost. And actually you don't pay tax on the labor either. All I put on the customs invoices for European clients is $599 for silver, or $639 for black. Unless anyone has a problem with that. In that case I can make it as high as you want.And I don't use Fedex. I use DHL. There's no clearance cost.So:$599 purchase price 487€4% import duty on the above amount = 19.44€21% VAT = (487+ 19.44 x 0,21) = 106.4€Shipping cost 81€total = 730.6 + 19.44 + 106.4 + 81 = 918€ Shipped to your door in 4 days all cost in!
Pre-Tin Plated SteelPre-tin plated steel is an ideal low cost solution that works well from lower frequencies in the kHz range through frequencies into the lower GHz range. Carbon steel has a permeability value in the lower hundreds range which provides the low-frequency magnetic shielding property that is missing in alloy 770, copper, or aluminum. The tin plating offers corrosion protection for the steel to prevent rusting as well as providing a great solderable surface to attach the shield to the traces on the surface board during assembly.
Material CRSPlatingMatte Tin
The most common material used in the manufacture of chassis for consumer audio equipment is electro-galvanized cold rolled steel. This material has the capability of providing adequate electrical and mechanical strength for many applications...
