0 Members and 1 Guest are viewing this topic. Read 89234 times.
FILTRO SHAFFNER - Come filtro di rete viene utilizzato uno Schaffner FN284-10/06 con interruttore a bascula bipolare, presa IEC C14 e doppio fusibile (Ø5 x 20mm). Corrente massima 250VAC, 50/60hz, 10A. Induttività nominale 0.34 mH(2x) mH. Capacità CX220 nF. Corrente derivata <373 µA. Attenuazione @ 150 MHz: 13 dB. Attenuazione @ 10 MHz: 52 dB
• Power rating (single channel driven):1200W @ 4ohm600W @ 8ohm• Power rating (both channels driven):700W @ 4ohm620W @ 8ohm*** IMPORTANT NOTE *** The Amplifier is capable of delivering 1200W @ 8ohm when driving only one channel. As many people assume, that they get two channels with 1200W power we want to clear up this misconception, so that you will not be dissapointed when you receive the amplifier.
Apollon has lowered the price of their amp to 990 EUR + (Austrian) VAT, so it is:* 990 EUR for non-EU customers* 1,188 EUR for EU customers
mocenigo by mail:I have updated the first post.
I checked the shipping rate on Appolon Audio's website last week, $68 to Missouri. Rouge and Nord was around $105.
All of these amps are about the same price, some have slightly nicer cases and they cost a little more. Wiring is slightly different as well but I'm not sure how much difference it really makes.
For someone who doesn't own and has no intention of owning an AS1200 based amp - you sure post a lot about them.... I have no issue using my Mivera Takachi case AS1200 amp with my horns which have a sensitivity of 100db.If you want real feedback about the AS1200 look at the Mivera feedback threads- real info from actual owners of the amp, not just conjecture and speculation from guys who don't even want the amp.
PS Audio make some great gear, I used to have one of their dacs. The M700 looks like a nice amp, but the 700AS is a lower end offering than the 1200AS from Icepower. The 1200AS does not benefit from an input buffer, and can be had for a lot cheaper than the M700. As 1200AS based amp seems more appealing to me.If you rate the M700 so much are you going to buy a pair?
Who knows? Just looking at all my options. I have never heard M700's BTW. All reviews are just reviews until you get to hear the equipment yourself in your system. Everyone here knows that. 1200as reviews are no different.
If the ice edge technology is only in the 1200as, then that is probably what I will buy. There are now five companies making the 1200as ice edge, and I am sure there will be a lot more before the year is out. Also, PS audio is getting some great reviews from mags and real owners on their icepower amps. Check out their website. M700's are now rated Class A by Stereophile.Maty also posted a lot on these companies, has he bought one yet?
