0 Members and 1 Guest are viewing this topic. Read 24522 times.
SIGNAL TO NOISE RATIO 75dBA (A-Weighted), 70dBr (unweighted), relative to 2.83VRMS output
SYSTEM DISTORTION CRITERIA <10% THD at maximum output with full compressor / limiter engagementELECTRICAL DISTORTION CRITERIA 0.2% THD @ 1kHz / 2.83VRMS output; <1% THD @ 1kHz, full rated output
I don't see any indication of this being a per pair price. At $149 each it seems high. Haven't I seen these same speakers on here for $200/pr.?
* Passive: KEF Q100 is the best option if you like all type of music, very well interpreted and recorded.* Active and < $200To modern music, maybe the JBL 305 and others. But only to modern music, so badly recorded. And with a high volume so that the SNR is better. TV and movies too.All type of music, very well interpreted and recorded -> Focal Alpha 50 but $250 x2.
The problem is the same: cheap class D amp.
In the old JBL you can hear hiss when they work in nearfield. You know, cheap class D amplifier.
After I bought the Schiit Bifrost Multibit to replace my old Yulong DA8 and trying to listen to the advantage of this "multibit" DAC, I started to feel like the "multibit" is more marketing maybe, that and measurements of the cheaper Schiit DACs are making me wonder about things.As for why I chose RME it is a bit of a long story; a few months ago I bought the Massdrop JBL LSR-30X, and I can honestly say the sound quality for just $280 (even lower now) was just mind blowing to me. I usually listen to my HD 800, and I was expecting the JBL LSR-30X to sound vastly inferior and honestly I did not feel like the 30X sounded vastly inferior at all. I mean sure the HD 800 digs deeper and has more detail but the JBLs sound so good to me. In terms of enjoyment level the JBL is arguably even better possibly (HD800, I am slowly finding sounds a bit too bright for me?), my only gripes with the JBL is that the hiss at idle is very annoying cause I use them in nearfield and the connection options are all pro connection options and not really suitable to what I am using (Had to buy a few extra rca to xlr cables to get the thing to even work)...
