0 Members and 1 Guest are viewing this topic. Read 14268 times.
Hello every one in St Louis audio scene. Been away from StL for awhile moved up to Northeast MO....
I guess horn speakers are my favorites. Except those puny wimpy simpy girly horn Lowthers. I can piss louder than those single driver speakers. Ill talk more with you guys later..... LoL
Scott...... Please dont take offence... I won,t kill you,,,,Yet. My expierence with Lowthers go back to Lowther cornerreproducers Model T.P.1 Type A and model D Also the Acousta 115 folded horn. Also ive heard the Mauhorn IV, & V . in Chicago many times. The bass is still week. They still lack that slam and peel the green off your teeth that you can get from ...JBL Hartsfield,s or Klipschorns... Even with the cheapass drivers Klipsch uses. Thats why I modified the drivers in mine. ...
... But debbie said get an early start & pick on some body else.
....But when Some of these newbe amp scratch builders place 1 watt and 2 watt woosey amps to a horn system and claim audio uphonic bliss I just want to PUKE in their face....
Western Electric 300b Were made for the telephone company. Thats where they do best.
If you want to hear Lowther,s Really speak. Mount 16 Lowthers per channel in the wall (a sturdy wood wall) I heard some thing like this at BEATTY STEREO in Kansas City.
The electrostatic speakers were 15 feet tall. by 5 feet wide. the woofers were set into concrete baffles 2 24" Hartleys per side. Levinson amps & electronic xovers. Studer tape recorder & master tapes . London Symphony orchestra. Beehtoven ,s 9th The clarity ...most believeable. You could almost smell the rozen on the violin strings.
You also need to know, my all time favorite speaker I've heard is the JBL Hartsfield. The one Classic Audio Reproduction makes with the TAD drivers.
300b tubes are fine ....Single ended is fine.....Good simple circuits... If you like to wipe out your voicecoils. Get on the Pro JBL site and read the technical note ...Danger: Low Power I believe it was write,n by Dennis Klietch The dangers of running amps close to clipping The killer distortion.
..... Yes I,m opinionated . The audio scene in Stl Has slipped into HERISEY. And I intend to drag those sinners to the stake. ...
The Paragon system is flawed because only the 375 is used splayed across the curved panel.
ScottF :A bit of history on the original... http://www.audioheritage.org/html/profiles/jbl/hartsfield.htm [/list:u]Interesting reading !
Scott F.......On the audioheritage.org Click the lansing logo then the lansing library...Go to enclosures. Plans. There you will find complete plans for the HARTSFIELD. Download prints and enjoy.
