Osiris stand question
0 Members and 1 Guest are viewing this topic. Read 2265 times.
mca
« on: 16 Dec 2004, 11:34 pm »
My Osiris stands for use with my Onix Ref1s have just arrived. What a nice, well built, heavy stand  :D
I do notice the top plate that the speaker rests on is not perfectly flat but rounded a bit towards the edges. What have you found that works good in coupling the speaker to the stand?
I have heard some people say a mouse pad cut to size works good. Others love Blue Tac, even though I have no idea where to find it!
F-100
« Reply #1 on: 16 Dec 2004, 11:47 pm »
I use Blue Tac and you can buy it at Home Depot, Staples, Office Depot, etc ... for around $3/pack.
Mad DOg
« Reply #2 on: 17 Dec 2004, 12:04 am »
if u go to HD or Lowes, it might not be called blue tac but rather museum putty...it's located in the earthquake proof section along w/ the tv straps.
Mad DOg
Re: Osiris stand question
« Reply #3 on: 17 Dec 2004, 12:06 am »
Quote from: mca
i hear that mass loading the osiris' with lead shot further improves the sound.
F-100
« Reply #4 on: 17 Dec 2004, 12:12 am »
Quote from: Mad DOg
Good call MadDog. :)
eric the red
« Reply #5 on: 17 Dec 2004, 02:57 am »
At Staples look for Elmers 'Fun Tac' for about a buck and a half a pack and it's blue in color.
  • Speakers....What Speakers ?
« Reply #6 on: 17 Dec 2004, 04:36 am »
Between my speakers and Osiris stands , I've had good luck with a piece of rubber shelf liner cut to size. Really grips the speakers.... 8).
    [/list:u]
    Fife12
    « Reply #7 on: 17 Dec 2004, 04:49 am »
    I've used what Lonewolfy does too.
    Works great and easily available at the local "dollar stores".
    « Reply #8 on: 17 Dec 2004, 04:58 am »
    Red Dragon Audio
      • http://www.reddragonaudio.com
    « Reply #9 on: 17 Dec 2004, 06:59 am »
    Thanks lonewolfny42 for bringing that post back up.  I was going to start in about the sorbothane discs.  They're just great as they couple the speakers to the stands below about 150Hz-200Hz which improves bass response; really tightens it up and improves bass articulation/definition/blahdy blahdy blah.
    Then, above the 200hz point, your speakers are isolated from outside vibrational intruders (and the internal bass vibes were already transmitted down the speaker stands.)...it's really just a great match and not that expensive. $12 per stand.  so $24total outlay for what was a very marked improvement in my setup.
    One caveat about these sorbothane pucks; your speakers must weigh between 25-30lbs each in order to properly load the pucks.  So you might need to add a weight to the top of your speaker.
    I used a combination of leadshot and rice in my stands only b/c I couldn't get dry sand at the time.  I would say the best combination would have to be dry sand with fine lead shot (toss in a cup of rice to absorb any stray moisture). :lol:
    Rich Carlson
    « Reply #10 on: 17 Dec 2004, 11:40 am »
    I use sorbothane sheets from Edmund Scientifics:
    http://scientificsonline.com/product.asp?pn=3037000&bhcd2=1103283686
    cut to size to fit the top plate of my Osiris stands.  One warning, though -- over time, these will stick to and damage the finish on the bottom of the speakers -- use felt or something between pad and speaker if you care about this!
    Rich
    guest1231
    • Guest
    Speaker-stand topping.
    « Reply #11 on: 17 Dec 2004, 12:04 pm »
    I don't wish to sound oppositional (love that word!), but I would be careful using the shelf-liner recommended by lonewolfny42.  I have had some experience with that ype of product, perhaps a different manufacturer, or perhaps a slightly different composition of the material, but I found that it can leave marks which are not easy to remove.
    I think that this may be similar to, or the same as, the product Michael Fremer warned against using as a turntable mat.
    Best Regards.
    Lak
    « Reply #12 on: 17 Dec 2004, 05:36 pm »
    I also use the Osiris stand in one of my systems.  I prefer to couple the stand and speaker with Audiopoints (brass).  The point that Goldmund makes works very well also however is even more expensive.  I improved the Osiris stand sonically by filling the columns with Micro-bearings.
    mca
    « Reply #13 on: 19 Dec 2004, 02:00 am »
    Picked up a couple of bags of sand and a roll of drawer liner today at the Depot. What a difference that made :o
    For now, I'm just using my old Paradigm Mini Monitors. Not great, but much better then when they were on an old pair of wood TV trays  :lol:
    Can't wait until the Onix package arrives  :D
