0 Members and 1 Guest are viewing this topic. Read 6256 times.
Is this worth it to play with for HT only? How long should I set aside to play with this? I'm looking at the DSP1100 pro model
http://www.snapbug.ws/bfd.htmTry this link works great and easy to follow.
A brief Google search didn't turn up that model. I didn't spend a long time looking, though.
A brief Google search didn't turn up that model. I didn't spend a long time looking, though. I probably overstate the difficulty with learning it. I was impatient and tried to do it without looking at the manual first (like I always do! ). One day I should fiddle with mine some more and write my own brief tutorial, if for no other reason than if I should forget how to set up. It'd be easy to boil it down to a couple pages.Bubba, I didn't think my bass was bad, either. But the Behringer did wonders for it.
So what is the diff between the two then, smartass?
So do you just feed the Tact with the low pass? You aren't using it full range, are you?
