More Amazing DACs for Peanuts
0 Members and 6 Guests are viewing this topic. Read 385914 times.
ksbruce
Re: More Amazing DACs for Peanuts
« Reply #680 on: 20 Mar 2025, 08:49 pm »
thanks for this. I'll look into it.
Jon L
« Reply #681 on: 20 Mar 2025, 10:17 pm »
The Flyinsky tube DAC linked above by "viggen" is an excellent choice. At $225 and change ( Amazon) it's a tough one to beat. Easily competes with my Denafrips Ares and LM 502. Not to mention the 30 day audition/return option thru Amazon.
It has CS8412 receiver, so it would accept up to 48kHz signal only?  I also saw some reviews along the lines of "good musical sound lacking in detail resolution."  Does that improve with DDC, tubes, etc?
wushuliu
« Reply #682 on: 2 Apr 2025, 05:39 pm »
You can probably swap the CS8414 for the 8412 to get 96khz. You can get them on ebay.
SET Man
« Reply #683 on: 2 Apr 2025, 07:50 pm »
Hey!
    Yes, they are easily can be found on eBay. But desoldering that chip out and soldering that chip in is a pain though.
wushuliu
« Reply #684 on: 2 Apr 2025, 08:18 pm »
Hey!
You can buy them already presoldered to adapters just like the tube dac uses.
ksbruce
« Reply #685 on: 4 Apr 2025, 09:16 pm »
Mine does 96k. mine is stoock except for an upgraded NOS 6922.
zek
« Reply #686 on: 5 Apr 2025, 04:41 pm »
Mine does 96k.
In the screenshot I only see 88.2kHz, where did you get 96kHz?
ksbruce
« Reply #687 on: 5 Apr 2025, 11:45 pm »
Sorry I couldn't upload the other one, but it does play also.
ksbruce
« Reply #688 on: 5 Apr 2025, 11:49 pm »
wushuliu
« Reply #689 on: 11 Jun 2025, 03:31 am »
Finally hooked up the AD1865 tube dac. Very smooth, pleasant, warm. I like it. I swapped out the RCAs per usual for some AECOs which opened things up a little. Got a Reflector 6922 and some soviet 6z4s on the way to try out. Maybe replace the caps if I'm in the mood. Gonna leave it at that though.
zek
« Reply #690 on: 11 Jun 2025, 10:45 am »
Some link, please.
wushuliu
« Reply #691 on: 11 Jun 2025, 04:00 pm »
Some link, please.
Same one discussed above in the last dozen posts. The 'Flyinsky' version.
Alfi
« Reply #693 on: 13 Jun 2025, 04:30 pm »
@wushuliu
How does the "FLYINSKY" dac sonically compare to the LAIV uDac ?
Regards
wushuliu
« Reply #695 on: 14 Jun 2025, 07:28 am »
@wushuliu
Regards
I've only just gotten the flyinsky up and running, haven't had enough listening time with it yet.
ksbruce
« Reply #696 on: 14 Jun 2025, 06:15 pm »
Cannot be shipped to EU.  :cry:
My link is Amazon US. Try searching on yours. Several versions are on AliExpress, including XLR output.
Alfi
« Reply #697 on: 14 Jun 2025, 11:08 pm »
Hi,
What's your assessment of the LAIV uDAC ?
Regards
wushuliu
« Reply #698 on: 15 Jun 2025, 01:11 am »
Hi,
Regards
I think it's a great option if you're buying new and you like the current day R2R sound. On par w/ Holo Cyan 2.
Alfi
« Reply #699 on: 15 Jun 2025, 02:24 am »
Thanks for the info.  How do you describe "current day R2R sound"  ?  How does it compare to "not-so current day R2R sound" ?
Regards.
